Verify that you are using a microSD card (max 2GB), not a microSDHC (4GB or larger) card. You can use a microSDHC if you install RockBox on your Sansa C240, but it will be read-only. You will have to use an external card reader to copy media to it.
You need to use SD cards, 2GB or smaller. The S600 does not work with higher capacity SDHC/SDXC cards.
SD cards are getting a bit harder to find, but they should still be available at most department, electronics, or office-supply stores. And, of course, the usual online sources.
Hi there! Simply insert the card in it's adapter, then insert it into the memory slot. However you can buy yourself an external USB card Reader supporting your pro duo card. Please rate this advice as it's very important for us. Good luck friend!
Your laptop must have a card slot, for it to be able to read the card.
First most phones use a micro sd card, so you need the card holder, a card holder id a regular size sd card that you put the micro card into and then you put this into a sd card reader if the laptop has one.
Most laptops,computers, can not read a micro sd card, only sd card, and some mmc memory sticks.
You did not post who made your laptop, or the model number so we have no clue if your laptop has a card reader.
From what ive found the max expansion card it supports is 6gb they might offer support for higher capacity cards with a firmware update but as of right now no they don't
i) right click on Pen Drive Icon(icon showing your memory card) and select the option format and follow some onscreen instruction and u will able to format your memory card,,,,,
ii) try cut, copy, paste videos, songs from your computer and copy or paste them on to your memory card and u will able to use them in ipods, mobiles.... and lessons songs...
Make sure it's a Sandisc, Toshiba, or Panasonic memory card. No bigger than 2 MB unless you have done a firmware upgrade. Try formatting memory card and if that doesn't work then you will have to get a different memory card.
