20 Most Recent
SanDisk 2GB Secure Digital Memory Card Questions & Answers
Remove Write Protection from a 2GB SD Card
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps you
Camera & sd card got wet
There's no chance of you messing up the memory card further. Once the memory card dried up, you should be able to use an external card reader to look at the pics on it. This type of memory is less susceptible to corruption and therefore it can take a lot more punishment.
SanDisk Memory Card~Unrecognized file format
Insert your memory card into your computer's reader if you
have one. If not, you can purchase a multi-format USB Memory Card reader
from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This
is a non-reversible process so make sure this is what you truly wanted
to do in the first place.
6
Once the process is completed, take the memory card out and
insert it into your Digital Camera or any other device. Try to browse to
it to make sure it works fine now.
2gb...formatted...now phone says memory is full
have one. If
not, you can purchase a multi-format USB Memory Card reader from
drives.
5
Leave all the options as they are and click on 'Start'. This is a
non-reversible process so make sure this is what you truly wanted to do
in the first place.
6
Once the process is completed, take the memory card out and insert it
into your Digital Camera or any other device. Try to browse to it to
My memory card not formatted and it is not opened
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
#3
#4
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
After taking several pictures, I wanted to put
if you have a USB cable for your camera, you might try to synch the computer with the camera and transfer your pictures that way.
After you have your pictures on the computer, then you can obey your computer's wishes to format the card.
Windows can be exceedingly picky about these SD cards, and I don't know why.
I cannot delete images off my sd card.
Most likely, there is a switch on the side of the card. Flip it over from where it is now and then you should be good to go. If that doesn't work, select the file you are trying to delete and right click and go to properties, then unselect read only in the lower area of the window.
While transferring mp3 it shows an error
basically nokia mode is meant only for those if u want to use ur for for internet nad short term applications..........for storage purposes data storage mode is used
Memory card not formating
first check to see that it is not write protected (flip the switch on the side). if you cannot read from it and it still will not format, then it has probably been exposed to a static charge and is dead.
My SanDisk memory card for my HP Photosmart R740
The card may have failed on you or the write protect slide over enough to lock the card. Take the card out and looking at the label to the left is a notch on the side. In the notch will be a tiny button or slide. Move it to the top (away from the gold connectors) to unlock. If you still cannot delete you may have a dud card. You can try to reformat on a different computer or with a different operating system. For example windows won't work but Mac or Linux might work.
Lost my memory card Password
You could try and send it to a data recovery center, but I think the only thing that can be done is to reset the memory card (the data is deleted by doing this). I have the device to do it, but as I told you before, it also deletes any data.
How do I transfer photos?
when u insert card into PC, a window pops up close it, then open the my computer, double click the removable disk (J) if this 1 does not open D click another removable disk , once it opens, open Ur pics, then left click the pic and hold the left button and drag the pic on to the open window u opened for the SD card or right click the pic and copy the past it in the SD window, hope this help
