Blinking 4 times in standby mode
No
vertical Deflection (V STOP), Screen goes to a single horizontal line then the
video signal muted. Check IC1509, Q1505 If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2200 posts now. All are related to
electronic equipment repair help. Blinking codes to Sony TVs are described in detail.
SOURCE: standby blinks 7 times
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
SOURCE: Sony TV stuck in stand by mode
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
SOURCE: Sony KV36XBR800 standby blinks 4 times
The 4 blinks usually mans that there is no vertical deflection signal. Look for a small flat Ic with about 11 pins that may be marked LA7837 or something similar. Resolder the pins on that first. If that fails to resolve it, replace the IC.
Keep me posted.
Dan
SOURCE: sony KV-HR 29" TV GOES ON STANDBY MODE AFTER 10 TIMES BLINKING
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: Sony KV-27FS13 blinking standby 5 times..
try to resolder all ic leads and power supply component, moreover Horizontal section.
