hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater.
now if there is frost only on the bottom or top of evap coils u may have sealed sys problem
if u got an ? feel free to write me..
My advice to you is to transfer the meat to another place (preferably somewhere cold, for both the sake of the meat, and your freezer), let the compressor cool down, and then try starting the freezer. If it does start (it should), let it run until it has pulled the box down to 0 F. Then add the meat back in. Note at the beginning I told you to store the meat somewhere cold. It can be quite an overloading situation for the freezer, not only to have to pull itself down to such a cold temp, but when you add a bunch of "warm" meat to the appliance it is just to much of a load for it to handle. Hope this helps
I got delivery today for the same freezer and had the same question. I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
