20 Most Recent
GE 5 cu. ft. / 142 liter Chest Freezer FCM5SMWH Questions & Answers
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Ge chest freezer wiring diagram
Great question but I cannot answer it. GE makes several models of chest freezers and they are not all wired the same. My eyesight is not to good and I cannot see your freezer so I cannot answer your question. You might try our friend google and look for the make and model of your freezer with the prefix schematic.
10/2/2021 4:24:47 AM •
GE Freezers
Answered
on Oct 02, 2021
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
8/11/2017 2:07:14 AM •
GE Freezers
Answered
on Aug 11, 2017
