I had checked the fuse of the pop up flash its not blown out, it pops up but dosent fires but when i connect sb400 to it and it fires well. what might be the problem is there any thing wrong wrong wid the circuits how to check. please help
The flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
SOURCE: pop up flash nikon D80
There is a small hex screw on the underside of the flash pop up... next to the latch. I gave it a half turn and presto... fixed...
SOURCE: autofocus will not work,
the d40 takes a while to focus, make sure the subject is centered on any of the 3 focus brackets.next press the shutter halfway and wait until the camera beeps , when it does, press it all the way and the picture will come out crisp.
SOURCE: nikon d40 flash won't fire
My d40 did the same thing and the guy at Wolf Camera said a sensor is bad. The falsh was up but every time I focused it tried to pop up the flash again but it would not fire.
I had 2 options. Send it off for 8 weeks to Nikon at a $240 minimum or buy a flash attachment for $100. I chose the $100 option.
SOURCE: nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
