When I record a vinyl album on a CD it all winds up on one track.
I want to record analog with separate tracks for each song on an album so that I can select which songs I want to hear. How do I set up the recorder so that it changes tracks in between songs?
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
Make sure that your cables and adapters support stereo.
Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
Start playing the record on your record player.
Hit the red circle that represents the "record" button in Audacity.
Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
Hit "Stop" to stop the recording.
Stop the record player.
Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Go online and get audacity. It is a free audio editor. Once the record player makes a wav/mp3 file
bring it into audacity. Here the tracks can be broke down into smaller sections, tagged and fruther
processed. I presently use it with the old ashoned analog record player. Once I'm done recording
a whole side to a record I use audacity to break it into single tracks and tag it. I can usually tell
when a song begins and ends by the graph I just look for breaks. I can also use cut and paste
to chop out scratches, low pass, high pass, normalize and many other options. Audacity is also
completly free.
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Same just happened to me. I was using SONY CD-R audio 80 min recordable CDs. One burned 3 songs, the other 4 songs before giving me the "CD write failure" message. I tried another brand of CD-R, TDK CD-R, certified plus, and it worked first time. It played on my CD player, on the Ion, etc - works.
Maybe the CD burner in the device is very picky as to the brand or quality of the CD-R media? Try a TDK or other to see if that will do it.
-Good luck! Bill
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Select Recently Added, Artists, Albums, Songs, Genres, My Top Rated, Playlists, Podcasts, Audiobooks, or Recordings (Voice). - to view songs by album, artist, etc.
Or remove the track lisitng from the ID3 tag completely.
