20 Most Recent Numark ttUSB Turntable Questions & Answers
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
9/23/2022 6:40:56 AM • Numark ttUSB... • Answered on Sep 23, 2022
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
11/17/2017 7:08:50 PM • Numark ttUSB... • Answered on Nov 17, 2017
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
9/2/2017 1:01:19 AM • Numark ttUSB... • Answered on Sep 02, 2017
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
6/9/2017 12:29:59 AM • Numark ttUSB... • Answered on Jun 09, 2017
2answers
I've connected my turntable to
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
1/12/2016 7:44:27 PM • Numark ttUSB... • Answered on Jan 12, 2016
2answers
Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
1/12/2016 7:38:49 PM • Numark ttUSB... • Answered on Jan 12, 2016
How do I turn the volume up?
As it is a USB turntable it presumably connected via a computer. So the answer (if that is the case) is in the audio system of your computer. There should be an input control in it for the USB connection of your turntable. Adjusting that will increase the volume.
8/28/2015 7:57:03 PM • Numark ttUSB... • Answered on Aug 28, 2015
I cant get sound from my turntable. How do you hook it up?
As long as you can hear the record playing in the groove of a record, by ear, then the problem is that the connection to your computer is wrong. Since this is a USB turntable it will have to plug into a USB port. So you need to check that you have connected to the right type of USB port. That the port is working. See Control Panel on a Windows Machine. That the signal level from the port is set high enough and that it isn't switched off. You might also need to check the drivers for the device are installed and up-to-date.
4/3/2015 1:09:42 AM • Numark ttUSB... • Answered on Apr 03, 2015
There is a buzzing off and on through the recording any suggestions?
This will be an earth connection problem perhaps to the cartridge or connection lead. Look for loose fittings or a faulty lead.
3/7/2015 3:02:10 PM • Numark ttUSB... • Answered on Mar 07, 2015
BOTH SPEEDS PLAY WAY TOO FAST
Drive belt may have slipped, check speed on record, check if switch has another position or is not moving all the way, check if turntable is seated correctly.
1/4/2015 5:54:37 AM • Numark ttUSB... • Answered on Jan 04, 2015
I need to know the secondary output voltage of power transformer.
If the primary of the transformer has failed it doesn't follow that the main power supply parts are also faulty. However since the transformer is a safety part you need to replace it with the same thing. However it seems from this website that transformers are not expensive compared to a new deck, so a look around here might solve the problem.
5/8/2014 4:38:33 PM • Numark ttUSB... • Answered on May 08, 2014
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
3/26/2014 3:51:27 PM • Numark ttUSB... • Answered on Mar 26, 2014
0answers
Why doesnt the volume on my ttusb numark record
This is only a turntable. You will need an amp with a phono input to get any sound. For more information, please visit my website at audioserviceclinic.com. Thank you.
12/9/2013 12:43:31 AM • Numark ttUSB... • Answered on Dec 09, 2013
Installation cd for numark ttusb
have you tried the NUMARK web site
12/6/2013 2:12:50 AM • Numark ttUSB... • Answered on Dec 06, 2013
Numark ez converter software stops recording after 1 min
you must have set a marker on the rec track
11/4/2013 8:13:23 PM • Numark ttUSB... • Answered on Nov 04, 2013
Turntable rotating too slow
increase the pitch
11/4/2013 8:12:00 PM • Numark ttUSB... • Answered on Nov 04, 2013
USB Turntable not recognizing 2 channels
the channels are combined when you use USB as an audio input. when you play the deck does in come out of both channels?
11/4/2013 8:11:27 PM • Numark ttUSB... • Answered on Nov 04, 2013
What is a serial number?
you are jokeing right.
11/4/2013 8:07:56 PM • Numark ttUSB... • Answered on Nov 04, 2013
Numark ttUSB Turntable Logo
130 questions posted
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Numark Audio Players & Recorders
Most Popular Question
plate numark tt usb wobbiling
  • Audio Players & Recorders
