20 Most Recent Numark iDJ2 - DJ iPOD Mixer Docking Station Questions & Answers
Can I hook up a Numark 400 to a sound bar if so how?
Question edited for clarity Nunark to Numark. Question moved from Television category. You could use the line outs if the sound bar has the same jacks, line in. https://www.numark.com/product/ndx400 ..
10/22/2022 9:44:20 PM • Numark iDJ2 - DJ... • Answered on Oct 22, 2022
How demo mode disabled in numark idj2
To exit the demo mode, hit the "view" button.
10/26/2018 6:19:24 AM • Numark iDJ2 - DJ... • Answered on Oct 26, 2018
2answers
Why does my IDJ2 go into demo mode when i a
This is the default setting after you have updated the firmware. When you fire the idj2 up use the arrow keys to go into settings and change the "show demo mode" option to off...
2/13/2015 12:22:20 AM • Numark iDJ2 - DJ... • Answered on Feb 13, 2015
Even after callibrating my right deck, the pitch speed keeps jumping up and down... Any ideas how to fix this?
Hi, you have to replace the Pitch fader, which is causing this .It requires taking apart the IDJ2 and desoldering it from its board. You have to be exprienced with a soldering iron. The spare part is not too pricy itself, so maybe swapping out 2 of these faders at a time and also replacing worn out switches as a maintenance step. Regards, Regards,
1/3/2014 9:56:26 AM • Numark iDJ2 - DJ... • Answered on Jan 03, 2014
0answers
Idj2
Be the first to answer 12/11/2013 4:02:00 AM • Numark iDJ2 - DJ... • Posted on Dec 11, 2013Be the first to answer
3answers
Idj2 stutter start button
I have this same problem. I haven't found a solution anywhere, but a great workaround is using the Fader Start function - basically the moment the fader is slid into the main mix, the deck which you enable will start to play the tune. Hit the mode button, then select control, and turn on Fader start. It's actually really cool and allows you to do some ballsy mixes :) The deck will pause (or cue depending on the setting) once you bring it back.
11/6/2013 4:04:54 PM • Numark iDJ2 - DJ... • Answered on Nov 06, 2013
2answers
Hello, My Ipod touch is not
Hello, I've got the same issue!
My Ipod touch doesn't work with my mixdeck.
I posted a support request to numark last friday ... I'm waiting
My firmware release is the lastest.
Let me know any improvement
Thank
Phil
5/4/2013 5:07:18 PM • Numark iDJ2 - DJ... • Answered on May 04, 2013
Sometimes External drive mounts on
I spoke with Numark regarding intermittent cutting out of 750g Seagate hard drive. They claim the problem is with the size of hard drive and recommend using nothing larger than 500g. Bit of a shame really. Surprised no firmware upgrade to incorporate newer storage solutions.
4/30/2013 10:11:19 AM • Numark iDJ2 - DJ... • Answered on Apr 30, 2013
2answers
My Numark IDJ2 is having
Have you tried re-installing the firmware?
4/22/2013 11:31:58 PM • Numark iDJ2 - DJ... • Answered on Apr 22, 2013
6answers
My Numark iDJ2 won't update it's firmware!
If you have a Mac, from which you transfer the files, it will put extra hidden files on the USB stick. Remove these using a PC.
only the .upg file has to be on your USB stick.
Regards,
Jack,
2/9/2013 10:10:51 AM • Numark iDJ2 - DJ... • Answered on Feb 09, 2013
4answers
Microphone gos distorted after being used for two
Try a wireless mic system. If the problem persists I would return the unit to Numark. Me personally... I use the idj2 like a CDJ and have it lined into my DJ mixer. There is never an issue with microphones on my Peavey DJ mixer.
1/7/2013 9:43:54 AM • Numark iDJ2 - DJ... • Answered on Jan 07, 2013
2answers
I have static in my microphone on my idj2
My idj2 gets the same problem after 3 hours. For two hours it sounds good, I am using a shure sm58 radio mic. The only way i can get rid of the static sound is re booting the system then its ok.
1/7/2013 9:42:23 AM • Numark iDJ2 - DJ... • Answered on Jan 07, 2013
My idj2 keeps going into
go into the setup mode and turn of the demostration mode
11/14/2012 5:04:59 AM • Numark iDJ2 - DJ... • Answered on Nov 14, 2012
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
11/14/2012 5:02:07 AM • Numark iDJ2 - DJ... • Answered on Nov 14, 2012
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
143 questions posted
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Numark Audio Players & Recorders
Most Popular Question
numark idj2 update s firmware
  • Audio Players & Recorders
