First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out. The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch. One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter. If the error doesn't appear for several minutes then the pressure switch can be the source of the problem. Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer. Inlet valves can be purchased thru the net and fitted by you easily.
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
SOURCE: kennmore f3 stops and beeps during cycle flashes
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: F H beeping
ck fill hoses at rear connection and inside fill valve for debris..also be sure both faucets are fully on and there is sufficent water flow through both to washer be sure drain hose end is 30-36 inches from floor and fits loosely in standpipe ..allck ok then replace flow meter ..remove top on left side small round object with hose in each end 1 end goes to dill valve other to dispenser..flowmeter ckd for water flow into washer
SOURCE: Maytag Fronload Washer Error Code FH
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
