When it first started happening the F18 code also appeared when it was just on spin mode. I have now cleaned the filter and drained the machine (5 times), and have checked the exit pipe. The F18 error has not showed the last two washes, but water continues to pour out the bottom (I have stopped the last two washes after a couple of minutes for this reason). Any ideas?
SOURCE: Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
SOURCE: since i removed the filter for cleaning, water pours out
You can get a spare by quoting your make & model number, the part - your filter to one of the following. You may get diagrams of your part. Look for price, bargains, etc. You certainly don't have to replace the nice machine.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
SOURCE: Bosch Clasixx 6 wash machine
'F18' for Bosch normally indicates a draining problem. As you say the filter is clear, have you been able to check that something is not jamming the drain pump/motor?
So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If both the filter and pump are definitely clear, it COULD be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
