Culligan Sediment Water Filter Logo
Kent Posted on Mar 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panel says e 2
Softner runs constantly. Cannot change the panel read out to anything different. It says E 2
RJ H2O
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert 311 Answers
  • Posted on May 14, 2013
RJ H2O
Culligan Expert
Level 2:
Mentor:
Answers
311
Questions
Helped
184683
Points
362
By-pass the softener, unplug the control for two minutes, plug back in, put unit back in service (return by-pass to normal position). If unit continues run it has a bad seal pack assembly in the valve and it would need to be replaced. Or if it is stuck in backwash cycle this may home out the board and return valve to service position. If neither works you will need to call for service.
RJH2O
GE dryer runs but only heats on timed cycle not the other 2 cycles.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 17, 2015 • GE Dryers
tip
Fast program panel on windows
did you now that on windows you can make your all program panel show very fast than usually.
1. press the start button
2. find the menu called Run
3. the panel run will show up
4. type regedit and enter
5. and the registry editor will show up
6. press button ctrl + F on your keyboard
7. panel Find is show
8. type " menushowdelay " without space then press enter
9. after the menushowdelay edit strings found double click
10.change the number usually is 400 change with 0 or 1 then press ok
11. close all panel.the you can try the different from u all program menu on your windows
on Apr 09, 2010 • Computers & Internet
My tv flickers constantly now. Only 2 years. Flickers with anything --Netflix, cable, DVD, dvr, etc. Tried to change connection to different HDMI sources but problem continues. Help!!
does it do it on any other use ie tv free view scart or avi. is it just HDMI lead connections it could be a lose HDMI socket connetion that will need re sodering back on or that board is failing and need changing.
1helpful
My Culligan MC450S water softner has a blank flashing display. Water seems to be constantly running through the softner and pressing any display panel buttons has no effect.
This system should be under warranty still. If it is running to drain constantly bypass the system and call Culligan for service. Unplug it for 2 minutes and it may reset.
RJ
1helpful
Maytag Quiet Series 300 - Control Panel doesn't work
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
5helpful
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Top Culligan Measuring Tools & Sensors Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
