20 Most Recent Culligan Sediment Water Filter Questions & Answers
2answers
How do you change the filter to a culligan water
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing. Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.h2oservices.jpgl76w9ont156vs3p099e2rqu+8nt56e+fbm9ldnps+cnj57dmpqamzqoj3nqs4doe4cr7sqwf8acoamtivyaikaaaaasuvork5cyii=How to remove a stuck filter housing.1. Turn off the incoming water. 2. By-Pass the Softener3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).5. Press and hold the pressure relief button to relieve pressure further.6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone. 8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year. 9. Replace the cartridge filter and screw the housing back on. 10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.11. Open outlet and let water run to cold water faucet until all air is purged.12. Put softener back in service.IMPORTANT! Only tighten the filter housing by HAND! NEVER use the housing wrench to tighten the housing. I hope these tips help you with the angst of removing stubborn filter housings.RJ
7/10/2018 7:21:01 PM • Culligan... • Answered on Jul 10, 2018
Water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
11/19/2014 12:19:17 AM • Culligan... • Answered on Nov 19, 2014
2answers
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
5/23/2014 12:58:36 AM • Culligan... • Answered on May 23, 2014
Water has been trickling to the drain
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
5/21/2014 3:30:47 PM • Culligan... • Answered on May 21, 2014
How do i fix a code 5 error on a culligan 100
what does c5 mean? I can't get it off the digital face and had to by pass to shut off.
12/7/2013 10:29:41 PM • Culligan... • Answered on Dec 07, 2013
0answers
Has any one ever had a caramel like residue
I have seen salt attack aluminum like that but nowhere else
11/29/2013 9:48:40 PM • Culligan... • Answered on Nov 29, 2013
2answers
The phone icon is on calligan water softener, how
I have the same problem. Did you ever figure it out?
11/10/2013 7:03:37 AM • Culligan... • Answered on Nov 10, 2013
Panel says e 2
By-pass the softener, unplug the control for two minutes, plug back in, put unit back in service (return by-pass to normal position). If unit continues run it has a bad seal pack assembly in the valve and it would need to be replaced. Or if it is stuck in backwash cycle this may home out the board and return valve to service position. If neither works you will need to call for service.RJH2O
5/14/2013 1:20:53 AM • Culligan... • Answered on May 14, 2013
How do I clean the injector screen?
Cleaning injectors is a process best left to a professional with a bench setup to properly flow and clean them. In a pinch for a low cost short term fix you can do the following:1. Remove the + battery terminal.2. Remove the fuel rail retaining bolts and the injectors will pull out of their seat in the head.3. Remove the injector plug and simply pull them out. Look into the input side and you should be able to see if it is relatively clean. Sometimes they are completely clogged on older vehicles.4. Use Seafoam injector cleaner and spray into the input while pulsing the nozzle in and out until it is clear. Also spray some into the nozzle end.5. Repeat for all injectors, let them sit for an hour to 24 hours, then repeat the cleaning with the injector cleaner to force out any residual.6. You can also energize the relay with 12V and spray through the nozzle, but this is difficult without having a pressurized system.7. Reinstall (preferably with new O-rings) and enjoy. I did this recently on my son's 1999 Mitsubishi Mirage due to 2 cylinders not firing at all and it runs like a champ. Cost me $10.99 from Autozone. You should also replace the fuel filter at this time.
12/28/2012 12:17:38 PM • Culligan... • Answered on Dec 28, 2012
LeAking pressure valve on water filter h
Usually this is because iron/sediment has built up under the button up in the head of the housing. There is a spring that holds the button closed. If you can look up inside the head (with filter housing off) you will see a phillips head screw. Remove the screw and the spring and button come out. Clean the area thoroughly and lubricate lightly with silicone lube. Re-install and test to see if still leaking. If so you can try getting a new spring at hardware or replace the entire housing.RJ
11/11/2012 2:15:59 AM • Culligan... • Answered on Nov 11, 2012
Culligan Sediment Water Filter Logo
140 questions posted
Top Culligan Measuring Tools & Sensors Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Culligan Measuring Tools & Sensors
Most Popular Question
salt bridging in culligan water softener
  • Measuring Tools & Sensors
