I have changed all the ink cartridges, several times and the printer still won't print. The message will say one color or the other is low, but they are all brand new. I think we only got this printer to actually print once or twice since we bought it. I am so ready to throw this POS through a wall!!!
SOURCE: Can't seem to print in black only.
Are ya sure it isn't only preventing scanning direct to printer output? Is it also disallowing scanning to file? Epson printers canĀ“t operate if one of the cartridges is empty. There is no workaround for that. Epson printers actually use a LITTLE ink from ALL the color carts, even when you select "black only" in the driver. They do this to help keep the nozzles from clogging in the case of users who mostly print in black. Nobody [besides perhaps Epson] ever claimed Epson printers were the most efficient or environmentally-friendly ones in the world. for quite a while now Epson uses piezoelectric printheads, as opposed to the thermal heads used on most other printers. The enemy of piezo heads is air bubbles. They candamage the costly head, and that's why you cannot continue to use the printer if ANY individual cartridge runs out of ink. In fact, Epson designed its cartridges to signal "empty" when there's still around 15% (higher by some estimates) ink left! That's to make certain you can't run the cart completely dry and thereby introduce air into the head. If you don't believe that, carefully open up a spent cartridge over a sink, slice open the plastic film covering the various ink channels and rinse it out -- repeatedly push in the spring loaded outlet valve as well. There's so much ink left, it will take quite a while before the water begins to clear! It's incredibly wasteful and annoying, but it actually saves money in the long run, because it's even MORE wasteful to run tons of cleaning cycles just to purge the head once you've gotten air in the system. Aftermarket carts and ink can save lots of money, but they're a crap shoot. Fed up with OEM price gouging and scare tactics, I decided to try a clear-cartridge refill kit for my R200. The RX600 uses the same kit: http://www.inkjetcarts.us/servlet/Detail?no=8 Good Luck!
SOURCE: Printer will not use the magenta color
You did not say what the results of the check pattern showed. Were all the lines present or were there some missing?
If lines are missing, follow the instruction in my previous posts for under head cleaning.
If check pattern is good then you may have a problem with a vacuum pipe. You can download a rescue kit for CX machines to help with this problem from tradebit
SOURCE: blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
SOURCE: EPSON Stylus NX110 - 1st Ink Cartridge Replacement
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color. And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
@Inky Fingers - The check pattern lines were only light( almost gray) blue. Most times they were missing all together. Yes tape was removed! @ Bob Ha, after reading your post, I am convinced replacement is the only solution!!! Thank you for your input, perhaps this will convince my husband!
