20 Most Recent HP Hewlett Packard Deskjet 5650 InkJet Printer Questions & Answers
2answers
Teardrop light is flashing yellow. Green clock at
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
1/13/2018 12:48:07 PM • HP Hewlett... • Answered on Jan 13, 2018
3answers
After installing re-filled ink cartridges, both
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
8/4/2011 4:49:07 PM • HP Hewlett... • Answered on Aug 04, 2011
0answers
Cannot find our manual for
here's the link for the manual directly from the hp website
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00212924/c00212924.pdf
6/11/2011 9:59:25 AM • HP Hewlett... • Answered on Jun 11, 2011
I can't find the manual
4/29/2011 7:14:25 AM • HP Hewlett... • Answered on Apr 29, 2011
2answers
Left front indicator tear drop
The tear drop light is your ink cartridge light. If your having an issue with this one you should try and remove and r reinsert the cartridges if that doesn't work replace them. All of this information can be found with step by step illustrated instruction at the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=304445#N4482
reference the print cartridge light is blinking section.
Thank you,
Lee
2/2/2011 7:56:33 PM • HP Hewlett... • Answered on Feb 02, 2011
The color application on my
10/5/2010 12:22:03 AM • HP Hewlett... • Answered on Oct 05, 2010
Here is one HP could not solve. On the first page
This page addresses recurring paper jams.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190380&cc=us&lc=en&dlc=en&product=304445
If you complete all the steps and you still have the recurring jams, your printer likley needs service.
I am an HP employee. I do not represent HP on this site.
8/29/2010 2:07:05 PM • HP Hewlett... • Answered on Aug 29, 2010
Hp 5650 will not respond to LANDSCAPE
open printer and faxes go to printing preference then click printing shortcut there you can see orintation select lanscape apply ok it will work ,Also select page size A4
8/1/2010 2:19:10 PM • HP Hewlett... • Answered on Aug 01, 2010
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
4/15/2010 6:43:13 AM • HP Hewlett... • Answered on Apr 15, 2010
My dell v305w printer is blinking with an exclamtion point
Well Its on stand by mode or else the cartridges are not installed properly just try and restart u r printer make sure the cartridges are up and try and install drivers of it on u r laptop or the desktop for better work also try and check use manuel worst case call dell 1800 456 3355 Take Care
Thanks
1/29/2010 12:19:45 AM • HP Hewlett... • Answered on Jan 29, 2010
3answers
How do I insert the ink cartridges into the hp
Here's a link to your User Manual. Go to page 36 and it will walk you through the process.
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
12/6/2009 5:40:36 AM • HP Hewlett... • Answered on Dec 06, 2009
I want a software for my printer.
No Problem! Just go to HP.com/Support and download it.
There is one thing, however. You must get THE software for YOUR Deskjet. HP lists four different models for the Deskjet 5650 series. The 5650, the 5650w, the 5652, and the 5655. The software MAY, be the same for all models of this series, but I don't take chances, and give erroneous information.
Viewing the Deskjet from the front, the model number is on the lower right side.
Here is HP.com/Support, the page for the Deskjet 5650 Color Inkjet series, and the specific page that you choose which model you have,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Deskjet+5650&submit.x=3&submit.y=2
I'm going to click on the top model listed, HP Deskjet 5650 Color Inkjet Printer,
as an example.
Now click on the -> Software & Driver downloads heading.
Now choose which Operating System you are using.
I see they only have the Diagnostic Utility available, if you are using Windows Vista.
If you are using Windows XP, they have the full software package available.
(HP Deskjet Full Feature Software and Driver -Date: 12-2003)
7/12/2009 7:30:04 PM • HP Hewlett... • Answered on Jul 12, 2009
Can't find my manual - need to change ink
You can find a description of how to change ink cartridges here.
If you don't have a manual, you can download it from here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
7/4/2009 9:30:09 PM • HP Hewlett... • Answered on Jul 04, 2009
Can't change cartridge on HP 5650. Carriage and
With power off, remove the cartridges, move cartridge holder to middle of print area, and then look inside the cartridge loading area at the bottom of the printer. There should be a cotton pad that catches the excess ink when the cartridge is cleaned. I've found on numerous occassions that this pad will sometimes get caught up in the mechanism and bunch up. Once it gets bunched up, it will not allow that back area to drop down to install the cartridges.
You'll get ink all over your hands, but you should be able to move the internal mechanism directly below the cartridge loading area towards the back of the printer and then try and untangle the cotton pad and flatten it back out into the proper position. if you can get this done, reapply power and see if the problem is corrected.
5/22/2009 10:15:50 AM • HP Hewlett... • Answered on May 22, 2009
HP Hewlett Packard Deskjet 5650 InkJet Printer Logo
32 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
find manual need change ink
  • Office Equipment & Supplies
