By grounding it will the dvd player work
This use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
SOURCE: POWER ACOUSTIK PADVD-330 DVD Player issues.
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
http://cgi.ebay.com/Pioneer-IP-BUS-Aux-In-Input-Adapter-CD-RB10-for-iPod-a3_W0QQitemZ400030920263QQcmdZViewItem
SOURCE: bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
SOURCE: My friend said he fried
Unless he connected the black to positive and the red and yellow to negative, it should not have fried his dvd player.
