20 Most Recent Kenwood Excelon DDX-7015 Double Din Car Audio Stereo DVD CD MP3 Player 6.5" touch-screen Car Video Player Questions & Answers
0answers
Ddx7037
Be the first to answer 6/16/2014 9:12:58 AM • Kenwood Excelon... • Posted on Jun 16, 2014Be the first to answer
Kenwood car stereo is displaying Protect and wont
If ur kenwood stereo is going into protect mode, it is because one of ur speaker wires is shorting out. Make sure all of ur speaker wire connections are good, and then wrap them so they aren't grounding out against the chassis. This should solve ur problem.
12/13/2013 10:22:40 AM • Kenwood Excelon... • Answered on Dec 13, 2013
I for got my password for my kenwood double din
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/dnx7140.pdf
3/30/2011 5:50:29 PM • Kenwood Excelon... • Answered on Mar 30, 2011
I cant use the bluetooth on my Kenwood Excelon
The Kenwood Excelon DNX7120 doesn't have Bluetooth integrated, in order to use, for exemple, a bluetooth phone you need to install a
3/3/2010 10:34:18 PM • Kenwood Excelon... • Answered on Mar 03, 2010
Where is the reset buton on ddx 7015
Remove fuse on rear
10/9/2009 7:47:00 AM • Kenwood Excelon... • Answered on Oct 09, 2009
Kenwood kdc-2025 car stereo
Do you have a test light, it would really make it easier for us to guide you thru a quick installation
9/26/2009 4:05:18 AM • Kenwood Excelon... • Answered on Sep 26, 2009
3answers
How do i bypass the parking brake switch in order for my video to play
ground the parking wire to groound wire
6/1/2009 9:20:59 AM • Kenwood Excelon... • Answered on Jun 01, 2009
2answers
DDX512 Video Playback Bypass
I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
3/31/2009 10:26:55 PM • Kenwood Excelon... • Answered on Mar 31, 2009
Kenwood KDC-X569
11/29/2007 1:47:43 PM • Kenwood Excelon... • Answered on Nov 29, 2007
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
Car Audio & Video Logo
Popular Tags
21 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
reset buton ddx 7015
  • Car Audio & Video
