Yes to re-install Windows.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
SOURCE: How to run recovery (located in D: drive) in Gateway Notebook Mseries 6816 laptop with Vista
Are you sure it not cause by virus? you can try online scan for virus. It might cause by virus that make system properly to work stable
SOURCE: gateway laptop battery issue
There is a smart circuit in the battery. Is sounds liek your smart circuit has failed. This will not affect the function of hte battery at first, but you need to get it replaced. This is how windows tracks the battery life, condition, and keeps the battery at peak condition. There might be a "reinitialization" application that might have come with your battery as well (some high level batteries have this) and it will recondition the battery and reset the logic circuit on the battery. I would highly suggest replacing the battery though if you do not remember having this software package. The logic circuit can not be replaced, and is generally there to keep you from installing generic batteries into the dell battery box. I hope that helps you in understanding what those lights are..
mrstan
SOURCE: I have a battery charging problem on my Gateway
hi, if the battery is new then you need to start looking at things like the charger. If the old battery was used for a long time, and as they have only a few months life span then this puts extra work on the charger due to the fact that when the battery is new it holds its charge and recharges fully now the problem is when the battery is old it dont hold the charge and runs flat alot quicker so this puts extra strain on the charger is its trying to charge a battery that wont charge properly as well as keeping the laptop working. This tends to cause problems with the charger due to it over heating so this is what i would look at first.
The second and less likely cause might be that due to the old battery over heating due to it not holding a charge this may have caused some components or solder on the circuit board to fail this isnt very likely but does happen from time to time.
What i would do first is take your laptop and charger into a small computer repair shop and just say to them you dont want any work doing but is their any chance you could tell me if my charger is working or not, play it like if i need a new charger youll buy it from them or if they say the board is damaged just say to them that you will bring it back when you have the money to pay for it. This way your not obliged to leave them with the laptop and you will then find out the fault for free. At least if they say its the charger then you could then get it off auction site instead of the computer shop.
Let me know how you get on or if you need further assistance.
Try this first though use the laptop untill the battery is totally flat i mean flat so much that it wont even light the laptop up then without using the laptop plug the charger in and then leave it to charge for say 12 to 16 hours so that its had chance to do a full charge from flat this then may solve your problem.
Also doing this process every month will ensure you get maximum life out of your battery
SOURCE: help! i've only owned my gateway nv52 for a few
Yup. Take it back to the seller and have it checked or replaced while your warranty is still up.
Hope this helps.
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
