20 Most Recent
Sony VAIO VGN-N250E/B Notebook Questions & Answers
Microphone is not working
If you have working sound, then go to:In Win 7 - Start > Control Panel > Hardware and Sound > Manage Audio Device> Sound > Microphone >Properties > Level. Make sure the microphone is not muted as well.
10/14/2012 3:12:19 AM •
Sony VAIO...
Answered
on Oct 14, 2012
I have sony vaio vgn-tx36gp,when
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
8/26/2011 6:24:02 AM •
Sony VAIO...
Answered
on Aug 26, 2011
HOW TO DOWNLOAD A VOLUME
if you mean a driver to enable you to use the speakers, etc. then you should check the VAIO website, or simply google "
Sony VAIO VGN-N250E/B PC Notebook drivers"
it should all be free
hope this helps!
8/16/2011 10:21:05 AM •
Sony VAIO...
Answered
on Aug 16, 2011
HOW TO CLEAN MY LAPTOP
I cleaned mine the other week by just a very hard blow into the slot. Hold you nose though or you'll get dust up it. If you take the base off then a very soft brush (such as makeup type) would be fine for dusting it off. Make sure you are earthed properly though.
2/6/2011 3:54:14 PM •
Sony VAIO...
Answered
on Feb 06, 2011
Laptop is frozen. No response.
Problem:
* Your HDD RPM(speed) is bad
*Processor Fan struckz
*over dust in ram
*High performance with low configuration
1/15/2011 8:01:55 PM •
Sony VAIO...
Answered
on Jan 15, 2011
My sony vaio laptop vgn-n130g
We cannot even suspect that it is a hardware issue beacuse you can get it into safe mode however you are not able to enter the BIOS.
Which is the operating system in your computer?
Since when are you facing this particular issue?
Did you make any hardware or software changes after which this happend?
Please provide me with all the above details.
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
1/10/2011 3:34:48 AM •
Sony VAIO...
Answered
on Jan 10, 2011
I have sony vaio PCG-71212M
if its not the messeduo hardware .it has to be thee driver ..no harm i trying
go to this page and download soun drivers for your laptop
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN250EB#div_pos_5
12/27/2010 8:59:00 PM •
Sony VAIO...
Answered
on Dec 27, 2010
