If your computer is able to go online through the
modem, that means the modem is working fine. You will need to connect the computer to the
router and the modem to the router. open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
please follow the steps 1. Turn on the router and connect the desktop to router 2. push and press the reset button,which is at the back of router, for 30 seconds and after that turn off the router for 30 seconds and turn it on after 30 seconds. 3. Now open 192.168.1.1 and check your router settings. 4. If the internet does not works then in the router setup page click basic settings, click MAC address clone 5. Select the enable button and click the Clone tab. Click save settings and turn off the router for 30 seconds.
Router set up. Router is not working. NO CD. How to set up router.
If you connect the computer directly to the modem, does it work? If that works then the modem is working. Now connect the computer to the router and the modem to the router. You will need to open the set up page of the router to check the settings of the router. You can set up the router without the CD also. It is very easy. Click Here for step by step instructions about how to set up the router
there is no specific life span for the router. As long as the settings on the router are working then the router will work. If the settings are not correct then the router will not work. Your old router might be still working. You just need to check the settings of the router. I believe you can set up the router properly. It is very easy. Click Here for more info about router set up.
