20 Most Recent Linksys Wireless-N WRT150N Router Questions & Answers
may be it's showing limited or no connectivity on your wireless connection where it's trying to connect or may be it's connected wirelessly but your wired connection is not communicating properly with router's switch, could be due to bad port on router or bad NIC or bad cable...check in your network connection.
Linksys... | Answered on Aug 28, 2018
Dosn't the router come with cables? Connect one computer to the router and see if it works.
If the router is brand new and hasn't been set up yet, it may have open wi-fi working right out of the box without needing a password. In that case, you could use a computer or tablet that has wi-fi, and no need for an ethernet cable.
Linksys... | Answered on Nov 27, 2017
Connect the Modem to the Router on Internet Port and the Computer to the Router on Ethernet Port1
Linksys... | Answered on Sep 27, 2017
I received no help..it was a wasted 2 hrs trying to understand the
technicians....I was promised that they could help me and the fee would be waived if
they couldn't....I have contested the amount with MC credit and explained that
I received no service. Don't know if I will purchase or recommend any
Linksys products after this awful experience. I wouldn't buy any program that asks for money up front and then doesn't deliver.....bad company and questionable value
Thomas B. Lucente
In a message dated 9/18/2008 5:42:49 P.M. Eastern Daylight Time,
support@linksys.com writes:
Sales Receipt
Service Support Number : CXC080918IOO7 Purchase Date : 2008-09-18 14:42:08
Purchased : Linksys Direct Connect (LDC) - Single incident For Product :
WRT54G2 with serial # : CSV00H622824 Case ID : 080918-015003 Price : 9.99
Total : 9.99 Customer Info : Thomas Lucente 1191 CREST RIDGE DRIVE
Bedford Tel : 5405863968 Email: lucentet@aol.com
Linksys... | Answered on Apr 25, 2017
try connecting directly with the modem.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Linksys... | Answered on Apr 03, 2017
Well ! this easy link advisor is not a good software to manage the network. It has some bugs. Some times even if you are able to go on line , it will show you that the router is not online. If you call the Linksys technical support, you will not get any technical support for the Easy link advisor. Even the Linksys is also not using Easy link advisor. They have a new software now called as network magic.
If you are not able to go online using the router, then you can try to set up the router maually. Ou don't need any CD or Manual or any software.
Click here for more information about router set up
Linksys... | Answered on Jan 03, 2017
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Linksys... | Answered on Feb 22, 2015
if you are facing anykind of problem with your linksys router then you can contact to our customer service LINKSYS Tech Support. we will surely help you to fix your problem.
Linksys... | Answered on Jun 23, 2014
you need to look at the back of your router you will able to see a blue color button . this button is known as wps button .
look at the back of your router you will able to see a button with the symbol of refresh or by the name of wps.
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Linksys... | Answered on Jun 22, 2014
The router's password can be changed by running the routers setup cd. If you do not have the cd:
1.Open your browser
2.In the address bar type in 192.168.1.1 this will bring you to your router configuration.
3.put in your username/password "If you forgot your username and password you can always reset your router, if that is the case your router will go to back to default settings,In order to reset the router look in the back of the router and you will see a reset button, press and hold the reset button for 30 seconds, the reset button is located next to the Internet port on the router.
4. When your linksys router configuration is up, go to Administration.
5. change password that's it!! hope this helped. Good Luck
Reboot
  • The most basic way to attempt to fix a router problem is to reboot the device. This is accomplished by unplugging the powericon1.png cord, waiting for a minute and then plugging the power connector back in. If the orange light continues to blink, you will have to update its firmware.
Download New Firmware
  • Even though the wireless router is malfunctioning, downloading new firmware is possible by disconnecting the malfunctioning Linksys device from the Internet connection in the wall, then using that jack to plug your machine directly to the Internet. If this is not possible, use another computericon1.png that can connect to the Internet. You can download a firmware update directly from Linksys (see Resources).
Install New Firmware
  • Once you have the firmware update available on the computer affected by the malfunctioning router, open the file and follow the instructions to upgrade the devices firmware.
Linksys... | Answered on May 12, 2014
Linksys website should have it look it up by model -#
Linksys... | Answered on Apr 23, 2014
You should just have to plug the N300 into a wall outlet, and plug an ethernet cable into the ethernet/network port. Access the N300 by typing 192.168.1.1 into your web browser's address bar to access the N300. It has been a while since I set one up, but if I recall correctly it should just ask you to choose the wireless network taht you want to repeat, select your home network and enter the password for it and save settings.
Linksys... | Answered on Jan 17, 2014
Have you gotten an answer yet?
Linksys... | Answered on Oct 12, 2013
Linksys Wireless-N WRT150N Router Logo
445 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
linksys e1000 wireless router wps button
  • Computers & Internet
