I have a Dell Dimension 8200. Try to upgrade RDRAM from 512MB to 1GB. After installing modules and power up, no video just a beep sequence of 5-2-2-1. Return to original configuration but pc will no longer boot and I all I get is the beep sequence. Back of pc has a error code of green, yellow, yellow, yellow -" Memory not detected". I think the BIOS/mobo detected memory it doesn't like and won't boot but it now stuck in that state no matter what. Remove the clock battery didn't help. Any suggestion?
TIA
I THINK IT IS MEMORY UPGRADE, ALSO MAYBE A PARITY ERROR, SOME MEMORY DO NOT NEED PARITY ON THE CHIP SET, AND IF IT HAS PARITY ON THE CHIP THAN YOU GET ERRORS,
REMOVE THE NEW MEMORY AND SEE IF THE MACHINE WILL WORK IF SO THAN THERE IS SOMETHING WRONG WITH THE NEW MEMORY,
RAM TYPE: EDO, PARITY AND NON PARITY MEMORY, FPM MEMORY, THE CACHING MEMORY NEEDTO TO HAVE L1 OR L2 OR EVEN L3 CACHING CAPABILITIES,NMI ERRORS .
not:::: EAch manifacture may have a different voltage in the curcuitry and it may have the wrong voltage but i think that way out there and not to even consider it.....
does the manufact even allow that much ram upgrade???
rod
