20 Most Recent
Dell Dimension 8250 PC Desktop Questions & Answers
Where are my driver's for Dell dimension 8250
Some may already be installed on your system. To let Dell automatically find driver updates for you, select Check for Updates.
https://www.dell.com/support/home/en-in/product-support/product/dimension-8250/drivers
Won't power on
What happens wen you turn the pc on ? What sound do you hear?
Can't find the reset Password pin near the Battery
If you are prompted for the Windows password, this would mean that your Windows user name is password protected. This is separate from the BIOS password. Resetting the BIOS password on your computer will not reset your Windows password. If you are unable to recall your Windows password, or if you do not recall setting up one, try to leave it as blank and see if it works. If not, your other option is to restore your operating system through a previous restore point. **WARNING: Be sure to try to backup important files before you proceed as this can cause data to be lost.** Try to boot using your Windows Disc and perform a repair install or a full operating system reinstall. Another method is to use the factory restore option on your dell computer if it is still available. To do a factory restore, restart the computer and as soon as the Dell logo/screen shows up, hold down the CTRL key on the keyboard and press the F11 key a few times and release both keys. once you get to the screen where you can choose to restore to factory settings select Restore then press Enter. Let it go through the process and select FINISH once you get the message that it is completed .
My fan is stuck on high
Boot into the BIOS (press F2) and look for a "Thermal Setting".
Make sure it's not set to the highest setting. You can adjust it to your preference and make sure to save before you exit.
I replaced the rubber band on my CD RW drive and Reinstalled it. Now, it is not recognized
Check your device manager to see if the drives show up at all.
Start>Control Panel>System>Hardware>Device Manager
If they show up as disabled or with warnings, uninstall them and then go to "Action" then "Scan for Hardware Changes". This will make Windows rescan your devices and re-install the cd-rom drivers.
If it still shows up as being unable to start, there is a registry fix available on Microsoft's website.
http://support.microsoft.com/kb/314060
If the drivers are installed properly and the drive isn't listed with problems, you may just need to assign it a drive letter.
Right click on "My Computer" and then on "Manage". There you will find the "Disk Management" console where you can assign it a drive letter.
Old Dell 8250 screen don't turn on at all. power
Hi Natalie, It sounds like the monitor has come to the end of its life cycle....You can verify that the monitor is bad by connecting it to another PC or Laptop using a VGA monitor cable, and seeing if it does the same thing.Gary
Dimension 8250 won't boot up
Things to Check When No boot...
1. Have you connected all the power cable?
2. Do you see any display?(including the power lights glowing)
3. Does the screen show you any blue screen error message?
4. Do you hear any beep noises?
5. Have you tried to install any third party hardware or software?
6. What do you think could have caused the issue?
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
