SOURCE: Tab printing on Xerox 7345
There is no tabs option on the 7345. I am glad you asked that.
I was recently at school on that product, there was no mention of tab printing, I went to the Xerox.com site to inquire and tab printing is not supported.
You can call 1-800-821-2797 and inquire there. They may have an undocumented solution for tabs.
Let me know if they do please.
You will need your machine serial number when you call.
SOURCE: Xerox 7345 red comes out orange. Performed auto
the wrinkles sound like the fuser, how many copies on the machine? when was the last service? copiers are like cars they need to have there maitenance
Testimonial: "Exactly what the Tech. said when he arrived. Thank you. Great info, right on."
SOURCE: I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
The CE Access Number screen will appear.
WC73XX only: Select a paper size and type using the paper supply button
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit
Item, Inc.
SOURCE: printing error on xerox 7345
Dear download the driver and re install your problem wil;l be get resolved make sure you have the pst script function enabled, if not please install pcl 6 driver.
