20 Most Recent
Xerox Workcentre 7345 Printer, Copier, Scanner Questions & Answers
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Unable to start,the waste bottle need to be replaced
Are you sure the clear section is cleaned. The waste box may have a chip on it that tells the copier I am full, so vacuum iy out will not help. if you see a clear sectoin of plastic that has to be clear or the sensors will read the box as full. Replace the box, recommend always have a spare, so that during a print job if it come up replace the box and keep running. Another could be you are required to clear a counter every time you replace the box as long as the counter is not clear copier thinks the box is full. Go to Xerox web site contact them Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Xerox 7345 error 008-164 paper is folded with jams and 008/164
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220
http://www.iteminconline.com/121k22220_121k22220-xerox-7760-registration-clutch.htm
