Sony KP-57WV600 rear projection has multiple faint white arched lines like a rainbow on the top half of the screen and the opposite on the bottom half of the screen. The problem is not evident unless the scene is very dark (black backgrounds).
I am not sure what the problem is without pictures. It is possible the Link Jean provided could help. I would get more info before attempting this fix. If the lines in the picture look like the lines the picture in the site, then I would say there is a good chance that link will fix the problem.
Please keep in mind many things can go wrong with TV
sets and you should really do a lot of research before attempting any
adjustment and or repair. There are also high voltages present in some areas of the set and can
reside even when the set is unplugged.
Hope this helps.
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved,
just with that one solution
Give it a try, it's free and simple :D
Had a similar problem , mine was like yours but with
different colors....fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
