The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
I changed the yellow ink after doing a couple of printing and copy the problem is solved
the same problem back again
The problem is solved by changing the fuser unit.
SOURCE: Bizhub C351 Magenta Image Unit Problem
Sir,
The print head assembly has failed. Replace the print head assembly
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
SOURCE: print error page Bizhub C351
hello
I resolve the same problem by restart (power off power on) the switch with pluged Bizhub C360.
Maybe it will help someone.
