SOURCE: Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
SOURCE: nikon d80 frame count
264 is the minimum number of shots you can fit onto the memory card. A shot with large areas of black or white uses less memory than a more complex image and so the camera recalculates the number of shots remaining and so the number appears to go back up to it's original value.
SOURCE: Nikon D80
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again. Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5,
check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
SOURCE: Nikon DSL D80 with "r02" error
normally, just removing the lens and putting it again you solve the problem. F-- problem means "there's no lens attached !"
SOURCE: While my Nikon D80 is Error 09, can I update the firmware?
i had the same problem, not solved yet...
i want tell you that was camera malfunctionig. you have to contact service center.
