20 Most Recent
Nikon D200 Digital Camera Questions & Answers
All my shots seem to dark no matter what settings
What Mode are you in? In many modes the +/- setting that is usually easily adjust on the camera is exposure compensation this has no effect on manual mode. If this is set to -2 many modes will take dark photos. If you shoot manual then ISO, F-Stop and Shutter speed are all you need.
PG UP error message
Did you change the USB settings in order to get the firmware on the memory card? if so, try to set it back.
If anything went wrong with the update process, like wrong memory card, touched a button while the update was running switched off or removed a cable. and and and. The camera can become damaged, or unusable. Nikon gives the advice to go to a Nikon service centre with the camera.
11/17/2016 12:26:39 AM •
Nikon D200...
Answered
on Nov 17, 2016
MTP USB device failed to install on Windows 7
Did you instal the software that came with your camera?
You also can download the new View NX from Nikon for free. Always first install the software, before connecting any device on your computer. Special what it is a device like a camera.
The computer can interpret a camera on an USB for: Now I nave to charge the battery. Or when you start the program to transfer pictures, now I have to download pictures, or some camera's like your D200, also cam be controlled remotely over the USB, if the correct software for that is installed.
The software windows needs to install has to be on the computer first.
All my exposures are dark experienced this once
Did you check the exposure compensation setting? The button is on the top right of your camera and is labeled with a "+/-" symbol. Press the button and use the main command dial to zero the setting.
All my exposures are dark - experienced this once
Exposure Compensation.
Press the EC button (southeast of the shutter release button, as viewed from above, marked with +/-). If you see something other than 0 in the control panel, hold down the button and turn the main command dial on the back of the camera one way or the other to get it to zero.
There is black dot in left upper corner, every
Common problem, easy solution. It is dust on the chip.
At first try to blow the spot away on the image chip. Don't use your mouth or air, but use the airblaster.
And there are special swap stick which can help. Go to a photodealer, they will have the swaps. If you don't trust yourself, it's on the image chip, let the shop do it.
Have lost 10-pin remote terminal plastic cover on
With this link you can order it in the Netherlands:
http://www.nikonservice.nl/shop/product_info.php?cPath=28_29_44&products_id=108&osCsid=e65de02d0023cefe07db0b1edd4b986b.
It will cost about €4.50 and p+p. Maybe they can help you with a servicecentre in your country.
Hope it will help,
Bye
Klaas
Hi I have a Nikon d200 and with a Sigma 50mm
I'm assuming this lens worked on another Nikon camera before and that the lens mount is for Nikon cameras. Make sure the aperture ring is set to "A". Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
Transferred pix are dark and muddy
This is Defective Camera Sensor. Any mark on it would
transferred to the Picture taken by the Camera. You could try to Clean
the Sensor.If that would Fix the Problem, that's nice unless you need to
get the Sensor replaced.
Let me know, if needed further
assistance.
Hope i helped you.
Thanks for using ' Fixya '
and have a nice day!!
