20 Most Recent
Nikon D80 Digital Camera Questions & Answers
What is error133
The Nikon D80, can't give that error.
Put brand and model in the question for an accurate answer.
3/17/2015 11:40:43 AM •
Nikon D80...
Answered
on Mar 17, 2015
Nikon d80 err code
While I can't speak specifically to the D-80, my D-90 users manual say the ERR message indicates a camera malfunction and can be cleared by tripping the shutter. The only way I can do this on my D-90 is to turn the camera off and back on. Sometimes, but not often, I have completely remove the battery and reinstall it. The users manual also says that if the problem persists to contact a Nikon service center. I suggest you contact Nikon support at
www.nikon.com before you consider repairs.
8/29/2014 2:57:07 AM •
Nikon D80...
Answered
on Aug 29, 2014
The FUNC button in the D80 does not work
In the menu settings, you need to assign the Func button to do something. The Func button alone will not operate until you assign a task. The tasks available are listed in the menu setting for the Func button.
8/13/2014 3:13:01 PM •
Nikon D80...
Answered
on Aug 13, 2014
Nekon d80 erro problem
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at
www.Nikon.com and discuss the problem them before contacting an authorized service center.
7/28/2014 6:01:44 PM •
Nikon D80...
Answered
on Jul 28, 2014
Nikon d80 reset button
On the top right side of the D-80 are two buttons marked with a green dot. They are the "AF" button and the "+/-" button. Press these two buttons at the same time and hold them down for several seconds. This will reset all resettable functions to the factory default settings.
7/28/2014 5:58:40 PM •
Nikon D80...
Answered
on Jul 28, 2014
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the
image quality and size settings.
7/14/2014 8:17:38 AM •
Nikon D80...
Answered
on Jul 14, 2014
D80 will not turn on...battery fully charged
www.nikon.com. They may be able to give you some suggestions. It appears from what you said that the camera is not seeing the battery and that may indicate that your contacts in the battery compartment are dirty and need cleaning.
7/1/2014 9:14:31 PM •
Nikon D80...
Answered
on Jul 01, 2014
PG UP ERROR IN NIKON D 200 CAMERA
Is this a D80 or a D200?If you had a failure during firmware upgrade, then your circuit board is trashed. Send it to Nikon - it requires software to replace.
3/21/2013 12:45:27 AM •
Nikon D80...
Answered
on Mar 21, 2013
