my driver side wiper went completely to the side and now it doesn't work at allmy driver side wiper went completely to the side and now it doesn't work at all
You can't post conmments that contain an email address.
If it were the motor neither side would move. Chances are its the linkage.
You'll probably need to remove the panel under the windshield to access the linkage and check it out.
Either the wiper arms are loose or stripped on the pivots or the wiper linkage is broken. Try tightening the arm to pivot bolt. If that doesn't work, remove the plastic cowling and examine the linkage. You can buy new linkage for it.
You will need to find where in the linkage the problem is. I would start taking it apart to see what is and what isn't working correctly. Autozone website has free repair manuals available online.
From your post, "Finally had enough and stuffed a small block of wood between the driver's side bottom of the molded plastic linkage frame enough to lift the whole thing enough to put a moderate amount of pressure behind the wiper blade..", it sounds like this box is warped or somehow out of alignment. Is it possible for you to buy this box from a wrecking yard? Has you car ever been in a collision? If so the frame may have so un-repaired buckling resulting in the misalignment.
The wiper motor must be directly linked to the passenger side wiper, and the driver side wiper gets its action from the passenger motion. probably the linkage from passenger wiper to the driver side wiper must be the problem. Under the dashboard you can check it, the linkage must be snapped off. (safety first)
First remove the complete passenger side wiper check and make sure splines on wiper are not stripped. If this is not the problem It could be a linkage bar from the wiper motor to the wiper off or disconected. Since both wipers share the same motor if one works the other should. Check this by removing both wipers and then "Cawl" (little black piece between the hood and windshield underneath the wipers) Underneath the cawl you should be able to see the windshield wiper motor, and linkage bar to both of the wipers. See if the bar is disconected from the passenger side. If it is than reconnect it. These are the only two possible scenarios.
Hi. I have an 83 toyota dolphine camper
--It won't sart un less I squirt gas in the carb after 24 hours of rest. Have you had any problem with your in this area. Thanks [email protected]
if you open the hood look towards the base of the windshield, you should see the linkages for the wiper arms. make sure the linkages are all in-tact and nothing fell off. if the linkages are all good, see if you can move the passenger side wiper with your hand, if it moves freely or with little resistance check the nut/bolt that hols it on at the end of the wiper arm. see if the nut/bolt is loose. tighten if needed. also you can remove the nut/bolt and check the splines on the wiper arm where it presses onto the stud and see if they are wiped out.
