Grohe Aquatower 3000 Shower Tower Handshower Panel Logo
Posted on Jan 25, 2009
Dripping shower head
Have a Kohler brand "shower tower" assembly that has begun dripping.How do I go about fixing this leak??
  • 1 more comment
  • llnj1962 Feb 01, 2009
    Joe,
    it is dripping from the shower head.....
    Thanks!
  • llnj1962 Feb 02, 2009
    JOE:
    The head is not leaking from thread connections.There is no diverter either as this is strictly a shower assembly.Water drips 24/7.
    The water flow and temp is controlled by a single round door knob shape control.Are there cartridges in this type of assembly that need replacing? Not real familiar with Kohler products,only the cheap stuff! LOL
    Tried downloading a photo of this item,but the file is too large..Hope you can help me out
    -LOU-
  • Anonymous May 11, 2010
    I CAN HELP BUT I NEED TO KNOW WHERE IT IS DRIPPING FROM?.......jOE
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Feb 01, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
Helped
63152
Points
83
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
1helpful
How do I fix a dripping shower head in a stand-alone shower? We have already tried to replace the valve assembly but it still leaks.
Obviously this is a leak in the valve. They are no fun to work on. Some of the higher end models of valve have seats that you can change and along with the ball and other hardware, that should stop the leak. If not you will have to replace the whole valve assembly.
Dec 16, 2015 • Home
1helpful
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 • Home
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
One shower head inn 3head automatic system does not spray, just drips.
there could be dirt in the shower head or the two way divertor valve. i would remove the shower head first.
1helpful
Hi, my shower faucet /head drips regularly how to repair the leak?
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
Shower stall in master bath of a 15 yr old home. the shower started having water problems after about 1 year, leaking water onto the drywall next to the stall. we have tried everything-recalking, sealing...
Did you use plastic pipe? What about the shower head? Does it have a rubber o-ring in it? Pull the pipe out of the wall at the shower head and peek inside for the o-ring. If it is there, just snug up the pipe, do not over tighten. We were ready with crow bars in hand to destroy a brand new shower we just finished, because we thought we had w broken pipe, Then the owner says he torqued up the shower head as tight as he could and I read where it had to be just finger tight. One more place to check is the faucet itself, take off the trim ring and look in there for drips. It could be filling up the wall cavity and stay wet for days. I would take apart the drywall on the other side before busting up the tile again. Check it out.
Apr 24, 2010 • Kohler Home
Kohler shower hose leak
If the problem is solely because of the rubber washer with screen you can buy any cheap replica hose and use the washer that comes with it. If the issue goes away you are done. If not, switch heads and see if the issue follows the head. If it does then there would be a crack in the head at the connection. If neither solves the issue then you must buy a new hose.
Apr 15, 2010 • Home
1helpful
Leaking group head
Remove the screw and screen, then the 2 allen wrench screws and check the spring and valve in there, they might be sitting incorectly, adjust and re-assemble. Check pic for help.
Top Grohe Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grohe Home Expert? Answer questions, earn points and help others
