SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
SOURCE: lopsided during spin
This can be caused by a brake that has failed. Try to spin inner tub with washer off. It should NOT turn. If it turns the brake is bad and is allowing the tub to spin when agitating. This causes clthes to bunch up.
SOURCE: Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
SOURCE: Maytag Neptune front load will turn on then off in 3 seconds....
hi there,
please supply the full model # on your washer.
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
