Hello,An F-05
means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small
panel at rear of machine reveals the pump, pull of the two pipes
(Plastic clips hard to get off, slide them sideways), remove wire and
unclip pump from base of machine by lifting locking tab and sliding to
the left, pump can then easily be cleaned.
Thanks
