Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error code f 05
I have got hotpoint wd640 front loader,it takes the water in than washes when it comes to rinse it stops and error code f-05 appears. thank you
  • 7 more comments
  • baha Sep 18, 2007
    excellent service ,solved in minutes.
    thank u very much
  • Anonymous Dec 21, 2007
    found pump to be jammed by screw and debris from my builders trouser pockets. removed pump and cleared of debris .reassembled , fault code f05 gone and all ok.easy fix .many thanks nick
  • Anonymous Jan 03, 2008
    my problem is a f04 code
  • Anonymous Apr 06, 2008
    fo5 error code how do i fix this
  • maniacwoman Apr 07, 2008
    f04 appears or f05 water does not go out
  • deano bravo May 27, 2008
    hotpoint wf640g fault code appears after washing but before emptying i have taken the pump 2 bits where is the filter located is it with the pump cause if it is i have cleaned this aswell to no avail
  • Anonymous Jul 08, 2008
    my wd640 washer dryer has stopped mid cycle,flashing f_05 ,my guaratee has expired this month .
  • Anonymous Mar 08, 2009
    I have the same problem, also leaked from underneath
  • Anonymous Mar 25, 2009
    I have the same problem!! now to flood the kitchen again ;-) lol.. hope it works.. ill let you all know
    Scholar:
  • 136 Answers
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Sep 17, 2007
  • 3 more comments
  • mandiemouse Feb 22, 2011
    Absolutely BRIlLIANT, cant thank you enough. It was a hair grip in the pump... just needed cleaning out. Saved us a small fortune!
  • Esteban1988 Aug 14, 2011
    Thanks for this. Finally got my washing machine working again. Found a bobby pin and a 20p piece I can stop borrowing mum's now!
  • Fee Vee Dec 04, 2011
    Brilliant - thanks!! Balanced our machine on 4 tins of beans so that we could get a basin underneath to catch the flood and found a Royal Mail elastic band wrapped around the pump!!
    Raised our machine to get a basin underneath to catch the flood and found a Royal Mail elastic band wrapped around the pump! Thanks for the tip - you've saved us a fortune!
  • tracyjord532
    tracyjord532 Jan 21, 2013
    how do u get the pump off as ive got this problem and scared of breakin it
This is brill! I phoned hotpoint who told me I needed an engineer with a computer and tried to flog me extended warranty. Found this tried it and it is working like a dream. I has small clog in the pump easily cleared. £100 + saved. Thamk you so much. Lesson learnt - dont trust hotpoint.
Posted on Nov 19, 2009
Many thanks. Read this solution and just saved ourselves alot money.
Posted on Jan 13, 2008
    New Friend:
Ive just had this same fault flashing on my wmf540, just took the pump off and found 6 coins and a broken chain, fingers crossed, the hose clips are a right laugh putting back on!
Posted on Feb 23, 2013
    New Friend:
My washing machine is showin code F-05 why is this pls help as idont know what to do
Posted on Jan 21, 2013
Hi. I had the same F-05 fault this morning. I looked up solutions, found this wedsite & followed the posting by -Whizatlt. MANY THANKS as we found a hair-grip in the pump!!!. Once removed it is now working fine. Your posting saved us a fortune!!.
Posted on May 24, 2010
Found this on my first go and it was realy useful. Just be careful when you pull off the two pipes as you will be up to your ankles in water hee hee just like I was DOH!!!!
Works fine now thanks again!
Posted on Mar 19, 2008
Why was you washing your builders trouser's, does he not have a washing machine?
Posted on Dec 29, 2007
3 Suggested Answers
SOURCE:
SOURCE: error code f 05
Great advice. That sorted the problem. And it made me £2.05 !!!
Yeah just undo the big jubilee clip, pull the big black hose down, take out whatever's blocking it, put the hose back on...and voila!!!
Thanks Gigwiggin...topman.
Posted on May 17, 2008
  • 5 Answers
this worked for me and I made 25p for the trouble:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Wd640 problem not pumping out f-05
Error code means pressure switch jammed on full.
Remove lower rear panel of washer
Remove large black hose fastened to bottom of drum
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well
Please rate my solution.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Error code f 05
Mar 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
12,761 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
