Sony Z1 problem in NTSC mode In the Pal setting 501 the camera works fine shutter speed gain and iris all work fine and i get nice pictures, switch to 601 ntsc and the lcd is black unless you put iris to 1.8 shutter to 4 or 8 and gain on high then you get a dark picture on screen... i have done a reset by pressing the little button top left hand corner where screen flips out. any help would be appreciated best regards Mark J
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
SOURCE: LCD Problem
I have seen backlight problems on the external LCD display. Take a flashlight and shine it on the external display to see if you have a picture. If you can see a faint picture, most likely either the backlight or backlight inverter has failed. Those LCD modules can be tricky to service because of the size. I would recommend a qualified tech for the job
SOURCE: LCD DOES NOT WORK ON SONY Z-1
Mine had the same problem and the repair shop replaced the faulty LCD screen uni, now it's fine again.
SOURCE: Cannot manually adjust or access menu on Sony Dvcam DSR-PD170
you need to set the auto lock to centre position , and then you need to check the camcorder,if still it doesnt work then you need to take the camera to a good engineer for repairs
SOURCE: sony camcorder model dcra-c123
If you bought your camera from a shop then you will have an inst book, the setting are clearly listed how to do what you ask.
