20 Most Recent
Sony HVR-HD1000U Camcorder Questions & Answers
Tape door on my sony HVR-HD1000 will not go down
hi,
the tape deck mechanism is faulty, the remedy is to change the mechanism. if you can repair it open take out the mechanism, remove the head, eject housing,and the sensors mechanism locking plate etc, then peel out the flexible cable from the mechanism, and change it.
Why is my sony hvr hd camcoder not switching on
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
How to transfer video to computer
Your owners manual will show you on page 74 how to connect the iLink cable between the camera and computer. If you have lost the manual, it is downloadable for free.
Im having trouble playing back my tapes on my sony
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
I have a sony hvr-hd1000u
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
[email protected]
How to cleane comcoder head
You will need a cleaning cassette- the same type that you record on, but with a cleaning tape in it instead of recording tape.
Touchscreen
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
