20 Most Recent
Sony HVRHD1000 Camcorder Questions & Answers
C.31
difficult i.link sony hvr-hyd1000 to computer
Sony camera cassette door stuck
Possible this can be a mechanical fault as the cassette body got struck because there was some stickers on the sides or if there was a loose link.
If so you can remove the top cover and gently tap on the cassetter as the cam is powered to allow the tape to wind back so as to eject.
If there is no unloading of the tape back to the cassette, then it can be failure of the loading drive, failure in the servo section in which case you will need to remove the covers and check the loadin IC, the power and the board.
Touchscreen
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
Sony DCR IP1E screen black
Replacing the flex cable on a camcorder can be a delicate and complex process, as it requires disassembling the device and accessing its internal components. Here are some general steps that you can follow:
- Turn off the camcorder and remove the battery.
- Locate the screws or clips that hold the casing of the camcorder in place. Depending on the model, these may be on the bottom, sides, or back of the device.
- Carefully remove the casing and set it aside.
- Locate the flex cable that connects the LCD screen to the circuit board. It may be taped or clipped in place.
- Gently disconnect the flex cable from the circuit board and LCD screen. Take note of how it is connected so that you can reattach the new flex cable correctly.
- Install the new flex cable in the same position and orientation as the old one.
- Reconnect the flex cable to the circuit board and LCD screen.
- Replace the casing of the camcorder and secure it with screws or clips.
- Reinsert the battery and turn on the camcorder to test the LCD screen.
It's important to note that the specific steps and tools required for this process can vary depending on the make and model of your camcorder. Additionally, if you're not familiar with electronics repair, it's generally recommended to have a professional technician perform the repair to avoid damaging the device or injuring yourself.
