20 Most Recent
Sony HVR-Z1 Mini DV Digital Camcorder Questions & Answers
I have a sony hvr-z1j...and when I log filmed foot...
Ha this sounds like you may have accidently pressed the AV button, it has special borders and setting within the camera, these are used for title effects and other tricks, just press the button again a couple of time filming and see if it vanishes.
3ccd is broken.
Dear,
the ccd is of 100 USD. Please let us know if you require some thing else.
Black screen
hello, the camera works?..only the screeen does not work?..i can give you a link from where to get the service manual maybe it will help, check below link:
http://goo.gl/iTQx0Vgood luck
What is the best HDV1080i
It complete depends what you are recording in! PAL or NTSC? and how many frames... FCP is customized to your camera settings, match them up and then capture away!
I capture mine using a PC because then you can play around with both MAC and PC editing platforms as MAC captures are encrypted to only run on MAC.
- Scott
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
