Unit pix intermittently and for no apparent reason will go into shutdown mode for seconds to a few minutes and then return to normal operation. I'm old TV guy but not very familiar with the LCDs. Tapping on unit and indiviual boards and pulling on cables does not duplicate problem.
SOURCE: How do I replace the convergence board in this unit?
Yes the board can be replaced, but you may also need to do some touchup alighnment to the convergence, and maybe need to reprogram the magic focus or whatever the ato convergence is called on your set, if it has that feature, Good Luck
SOURCE: Samsung DLP HLN5065 intermittent shut off and color scrambled display
bad light engine assembly.......
SOURCE: My TV keeps shutting off after about 30 minutes
No its the Lamp! Call FOX 1-800-227-5369 $109.00
other company wants $212.00 Part# BP96-00224A
SOURCE: My samsung ln52a650 blew a
U have all the tools and understanding basic electronic and also can do basic soldering?Yes.The tv power supply board,that the board,where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors components parts.It is usally have bulges or puffing up capacitors parts indication of components capacitors parts are dying and needed replacement.Replacement for those new capacitors component parts with the same Micro ferit and the voltages of those new components capacitors parts in a higher voltages like 5 or 10 voltages higher than the old components capacitors parts u are replacing for a better heat resistance for the tv operation of the tv power supply board for later on tv use.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: samsung clp 315w printer imaging unit won't pull out
Sounds like something is binding. Take a flashlight and look closely and be cautious that you don't damage anything
1 Press MENU to select SETUP.
2 Press or > to select the CLOCK mode.
3 Turn the Rotary encoder to adjust the hours.
4 When the hour has been adjusted, press the
Rotary encoder.
5 Turn the Rotary encoder to adjust the minutes.
6 When the minute has been adjusted, press the
Rotary encoder.
7 When the setting has been completed, press
MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
