20 Most Recent Broan-NuTone VX475 Bagged Central System Vacuum Questions & Answers
Lost suction but no cloggs in line
see the solution; God bless youHow to determine a clog in your hose Take your central vacuum hose and connect it directly to the dirt canister. After turning on the vacuum if the hose has normal suction here then the clog exists in your tubing. Click here for help with tubing clogs. But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below. check.gifPlug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out. check.gifOr, remove the hose from the inlet and push a garden hose through hose to push out the clog. Most importantly, the garden hose must be turned off and there should be absolutely no water entering your vacuum hose. check.gifOr, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
8/29/2014 4:15:34 PM • Broan-NuTone ... • Answered on Aug 29, 2014
0answers
13answers
Nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
11/18/2011 4:57:42 PM • Broan-NuTone ... • Answered on Nov 18, 2011
My Broan-NuTone central vac shuts off after I am
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
8/22/2011 11:58:45 PM • Broan-NuTone ... • Answered on Aug 22, 2011
4answers
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
3/29/2011 8:15:36 PM • Broan-NuTone ... • Answered on Mar 29, 2011
My VX550CC also shuts down after about 15-20
Some People Hu...........Make sure that all filters are clean if need be renew..Sounds like overheating fault resulting in Thermal cut out operating....Good luck
2/20/2011 8:15:01 PM • Broan-NuTone ... • Answered on Feb 20, 2011
2answers
I have the same central vac and the same problem
I don't see a problem. here. Post details and I'l be glad to help ASAP
2/20/2011 1:47:41 PM • Broan-NuTone ... • Answered on Feb 20, 2011
Nutone VX550 suction shuts off during normal use
NO SUCTION AT UNIT
1/29/2011 6:29:41 PM • Broan-NuTone ... • Answered on Jan 29, 2011
If my system is stopped up will it make a noise
Yes. A clog will cause the motor to work harder resulting in a higher pitch. To prevent the motor from burning out the clog needs cleared ASAP.
This could be something as simple as cleaning the filter, but it could also be a blockage in the hose. This will be more difficult to clear, but if you can attach the handle end of the hose to the vacuum and turn it on, it may clear it. If not, you'll probably need to take it to a repair shop.
1/13/2011 8:48:06 PM • Broan-NuTone ... • Answered on Jan 13, 2011
0answers
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
51 questions posted
Top Broan-NuTone Vacuums Experts
john h
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • Broan-NuTone Vacuums
Most Popular Question
lost suction but no cloggs in line
  • Vacuums
