20 Most Recent LG Heat cool Window Air Conditioner Questions & Answers
Reset the external breaker for the unit it should be next to the unit or in your power box.
LG Heat cool... | Answered on Nov 19, 2017
You need to have an AC tech come out and do some preliminary testing on this.
LG Heat cool... | Answered on May 12, 2017
Try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you have any other Air Conditioning Repair Questions don't be afraid to let us know.
LG Heat cool... | Answered on Jul 08, 2016
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
LG Heat cool... | Answered on May 07, 2016
the control is sensing a problem have it checked
LG Heat cool... | Answered on Aug 28, 2015
Does not sound right to me.My guess after doing what every he was doing he probably installed a start capacitor or repaired a burnt wrie, got the compressor running and charged for a lot of guess work. Just guessing.
LG Heat cool... | Answered on Aug 12, 2015
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.
If it is not then the compressor is not working and it is just blowing room temperature air.
LG Heat cool... | Answered on Aug 22, 2014
If the drain is clogged or the ac is not slightly tilted towards the outside, the condensed water will leak inside instead of outside where it belongs.
LG Heat cool... | Answered on Jul 19, 2014
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
LG Heat cool... | Answered on May 23, 2014
Check to see if there's power to the reversing valve, if there is, try tapping it slightly with something kind of soft. You should give the reversing valve solenoid a continuity check with an ohmmeter to see if it's open or shorted.
LG Heat cool... | Answered on Dec 07, 2013
If this is a window or wall mounted single piece unit, open it and check for a loose compressor or fan mount.
LG Heat cool... | Answered on Aug 24, 2013
how do I set it to heat up the room?
LG Heat cool... | Answered on Jul 21, 2013
LG Heat cool Window Air Conditioner Logo
Popular Tags
134 questions posted
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
central air conditioner unit comprssor
  • Heating & Cooling
