20 Most Recent Alpine CDA-9851 CD Player Questions & Answers
No Sound from rear speakers when playing cd Alpine CDA-9851
See page 13 in the manual and make sure BBE is the same across all modes (sources)
11/19/2017 1:50:20 AM • Alpine CDA-9851... • Answered on Nov 19, 2017
2answers
I have an Alpine CDA
Hello .... your Player show the counter is counting but you don't have any sound .. Check your Main connection between your Radio and your CD deck player it possible your sound terminal connection is unplug due to excessive vibration on a bad driving road
4/8/2014 11:13:19 PM • Alpine CDA-9851... • Answered on Apr 08, 2014
manual
I need a manual for the clarion cda 9851
You may download a copy of the manual here.
9/8/2012 7:59:28 PM • Alpine CDA-9851... • Answered on Sep 08, 2012
2answers
The XM reciever does not work. As I scroll through
I have exactly the same problem. I hope someone has the answer!
9/16/2011 1:55:39 AM • Alpine CDA-9851... • Answered on Sep 16, 2011
When i preset my radio
Make sure the yellow wire is connected to a source that still has voltage when the key is turned off. The yellow wire controls the memory of the deck.
7/25/2011 6:28:45 PM • Alpine CDA-9851... • Answered on Jul 25, 2011
Sound quit after using menu
go back into the menu and see if you turned the internal amplifier off. if you did, just turn it back on.
3/14/2011 5:16:33 PM • Alpine CDA-9851... • Answered on Mar 14, 2011
How do i set the clock for this cd player
You can get the manual on the link below. Page 6
http://a248.e.akamai.net/pix.crutchfield.com/manuals/500/500cda9851.pdf
1 Press MENU to select SETUP.
2 Press or > to select the CLOCK mode.
3 Turn the Rotary encoder to adjust the hours.
4 When the hour has been adjusted, press the
Rotary encoder.
5 Turn the Rotary encoder to adjust the minutes.
6 When the minute has been adjusted, press the
Rotary encoder.
7 When the setting has been completed, press
MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
2/6/2011 1:17:40 AM • Alpine CDA-9851... • Answered on Feb 06, 2011
Cd player cuts out when
do you mean the sound turns off when a cd is inserted into the deck? are you running your audio through and amplifier? if you are using an amplifier, you are probably using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remoter turn on) to turn the amplifier on. the blue wire turns off when you are not in tuner mode.
1/28/2011 6:51:58 PM • Alpine CDA-9851... • Answered on Jan 28, 2011
I have my ipod hooked
Hi, the RCAs in the back are usually outputs, not inputs. The specs on this unit indicate that AUX input is optional. Are the jacks you're using marked AUX input? If yes, what kind of cable are you using to adapt the iPod to the RCAs? If no, you may need to buy an adapter. There is one here: http://www.crutchfield.com/p_500KCA420I/Alpine-KCA-420i.html?search=kca-420i&tp=120
I got this link from the spec sheet here: http://www.crutchfield.com/p_500CDA9851/Alpine-CDA-9851.html?tp=5684
Please let us know if you have more questions, and thanks for using FixYa.
1/18/2011 11:14:28 AM • Alpine CDA-9851... • Answered on Jan 18, 2011
Dont know how tochange from cd to radio
Source button changes from cd, radio, aux, etc.
11/29/2010 6:07:01 AM • Alpine CDA-9851... • Answered on Nov 29, 2010
I'm having the same problem
try pressing the reset switch or disconnect power to the radio for a few minutes.
11/2/2010 4:38:23 PM • Alpine CDA-9851... • Answered on Nov 02, 2010
Alpine CDA-9851 CD Player Logo
79 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
