Had same problem with sony 42" when i was using it with a sky digital decoder it turned out to be the scart output on the decoder try change the scart to a different outlet there should be a second one on decoder.
this problem can also accure if the tv is overheating
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
This is a LCD projection could be problems in the LCD blocks. There is one for blue one for green and red.Also make sure the lamp is good and the door is closed right there is a switch there.
Remove the power plug and put back after 5 minutes. Go to User manual and check for TV button to restore settings to factory default. If nothing works, you need to go back to service center.
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV. Please check fan connectors and make sure all are plugged securely.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is. no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
my tv does not turn on small green light flashes then flashes red
