20 Most Recent Sony KDF-50E2000 50" HDTV Questions & Answers
4 RED BLINKING LIGHTS ON SONY TV
SEE ALL YOU PEOPLE COMENT BUT YOU NOT EXPLAIN HOW TO FIX IT ,OH SORRY ITS ALL ABOUT MONEY FOR ONCE IN YOURES LIFE BE GENEROUSE AND HELP THOSE HO CAN PAY TO FIX IT
2/25/2019 5:03:51 AM • Sony KDF-50E2000... • Answered on Feb 25, 2019
Hdmi inputs select
This is a 720P TV, please try set up your Samsung DVD play video out put format to 720P, then try it again.
9/2/2017 7:34:51 PM • Sony KDF-50E2000... • Answered on Sep 02, 2017
My 3 year old Sony kdf50e2000 lcd tv is shutting
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/13/2017 6:53:19 AM • Sony KDF-50E2000... • Answered on Jul 13, 2017
Sony KDF-50E2000 50" Lamp replacement
1.you have 10hrs
2.you can find them everywhere try eBay
3. It is easy except one thing you must have the original remote to reset the lamp counter
5/16/2017 10:54:58 PM • Sony KDF-50E2000... • Answered on May 16, 2017
The unit Turn on and off by herself and flashes green light repeatedly.
You have a bad power supply. Its going to need to go to a real sony repair center.
9/30/2016 8:09:11 PM • Sony KDF-50E2000... • Answered on Sep 30, 2016
2answers
KDF 50E2000 WONT POWER UP
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
12/24/2015 6:18:21 PM • Sony KDF-50E2000... • Answered on Dec 24, 2015
I have green lines running down the tv... Need to know if this is a problem worth fixing or it is going to cost more than its worth. And can I fix it or do I have to take it to someone?
The problem is the optical block, there is a website dedicated to this issue: https://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
10/5/2015 8:26:11 PM • Sony KDF-50E2000... • Answered on Oct 05, 2015
NO green led NO PICTURE NO SOUND???
The power cord is bad or check the on/ off switch
8/31/2015 8:17:59 PM • Sony KDF-50E2000... • Answered on Aug 31, 2015
6answers
Sony Shadow on top of screen
Please call sony Optical Block warranty extended to June 30, 2010
10/13/2014 1:07:42 PM • Sony KDF-50E2000... • Answered on Oct 13, 2014
2answers
Just replaced the lamp, worked for about 3-4 days,
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
9/2/2014 11:27:14 AM • Sony KDF-50E2000... • Answered on Sep 02, 2014
How to reach convergence adjustment?
These sets do NOT have convergence settings--they used a light engine. Likely if you have picture issues it is contaminated.
5/8/2014 3:59:16 AM • Sony KDF-50E2000... • Answered on May 08, 2014
Have a sony kdf50e2000. I have sound, but no picture at all. any advice?
DO you have any light at all on the screen? if not--likely a bad lamp. Worth a try before you condem the set.
5/8/2014 12:46:31 AM • Sony KDF-50E2000... • Answered on May 08, 2014
Sony KDF-50E2000 50" HDTV Logo
232 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
green lines running down tv need know
  • Televison & Video
