I have a '07 Dodge Ram Hemi 5.7 Litre 4x4 Quad cab with a 6 speed manual transmission. I have had trouble getting the truck in reverse, 1st and 2nd gear since I bought it used in July 2011. I had the clutch, pressure plate and throwout bearing replaced today after the throwout bearing broke. Now, it is even more difficult to get in these gears. Any ideas?
Check if you can change 1st &2nd gear with the engine stopped if you can do this easy the clutch is the fault, free play may need adjustment . If still hard fault is in the gear box.
SOURCE: dodge ram 2500 diesel Hard
The overdrive gear in the transmission is known to move on the output shaft making overdrive hard to shift into & eventually not at all
SOURCE: Dodge Ram 1500 4x4 quad
The Po700 code means that something is wrong with your transmission control module. The Po841 code means that your filter may be loose. Click on the link below to read more:
http://www.dodgetalk.com/forums/showthread.php?p=2629632
