Sony HVR-Z1 Mini DV Digital Camcorder Logo
Pat Murphy Posted on Dec 02, 2012
Final Cut Pro X and Sony HVR-Z1
Will a Sony HVR-Z1 work with Final Cut Pro X
3 Related Answers
TIPS72
DUSHYANT SINGH
  • 369 Answers
  • Posted on Mar 03, 2010
SOURCE: Trying to capture video from a sony dcr-dvd610 to
Connect your camera with the fire wire to your mac and choose easy setup a dv and u shold get the video in to capture
Anonymous
  • 10594 Answers
  • Posted on Jul 22, 2010
SOURCE: hvr z1 sony service manual, i need it!!
First expert answer is correct and I agree with him however, you can download required service manual copy from HERE for small fee.
Anonymous
  • 977 Answers
  • Posted on Feb 14, 2011
SOURCE: I need to transfer footage
What is the exact problem that you encounter?
Is the camcorder detected/recognized by FCP7? If not, make sure you have the latest updates for FCP7 and for Quicktime... get them here and here (accordingly)!
3ccd is broken.
Dear,
the ccd is of 100 USD. Please let us know if you require some thing else.
tip
Import MTS to Final Cut Pro X-Convert Sony PJ30V 60p MTS to H.264 MOV for...
The Sony PJ30V has more compression options than your average camcorder. Most of its video is recorded using AVCHD compression, which is today's industry standard. The HDR-PJ30V has 32GB of internal flash memory and it can record Full HD video using 60p, 60i, or 24p frame rates. The PJ30V comes with the same version of Picture Motion Browser (PMB) software that shipped with the Sony HDR-CX700V, which we reviewed earlier this year. The new version of the software is nearly identical to previous versions of PMB, except version 5.5 does allow you to import and work with 60p and 24p clips (something that is essential for the HDR-PJ30V). One big downside, we noticed in terms of editing, is that the 60p clips recorded by the PJ30V don't always play nice with mac editing software. Final Cut Pro version 5.0, for example. And Now <b>Final Cut Pro X</b> is available could be Downloaded from the Mac App Store. However <b>Log and Transfer was removed</b> in the X version of Final Cut. So all Pro mts camcorder owners who use Final Cut are looking for <b>HD Camcorder MTS Converter Software</b>. <br /><br />Here is the step-by-step guide to quickly use Final Mate for Mac to <b><a href="http://sony-mts-converter.com/2011/06/import-mts-to-final-cut-pro-x-convert-sony-pj30v-60p-mts-to-h-264-mov-for-editing-in-fcp-x/">Import/Convert Sony PJ30V 1080/60p MTS to H.264 MOV for editing in FCP X</a></b> on Mac. <br /><br />Step 1. <b>Capture native MTS from Sony PJ30V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Import AVCHD MTS to Final Cut Pro X</a></b> on Mac, and drag the .mts files already backup all mts recordings from Sony PJ30V to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. <b>Create a Movie for combine and convert Sony PJ30V AVCHD MTS 1080p footage</b>. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /> <br />Step3. <b>Convert MTS files to H.264 MOV for Final Cut Pro X</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mov) to choose output format for editing in Final Cut Pro X. You can then adjust video parameters to keep original video resolution, bitrate, framerate, etc with highest quality. The <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac MTS to Final Cut Pro X Conversion</a></b> will start <b><a href="http://www.aunsoft.com/final-mate-mac/">converting MTS to H.264 MOV</a></b>. <br /> <br />After the conversion, the AVCHD videos could be imported to Final Cut Pro X with 60fps highest quality. Of course, you also can choose <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format for without rendering. ProRes is advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camcorder, please visit the <b><a href="http://www.aunsoft.com/camera/sony.html">Camcorder column</a></b> for more information.
Cannot import videos from sony hdr cx 210
Trying MTS Converter for Mac support convert AVCHD MTS/M2TS to ProRes, AIC, DNXHD MOV etc. for Final Cut Pro, Final Cut Pro X, iMovie, Final Cut Express, Avid Media Composer 6 compatible format on Mac OS X 10.5, 10.6, 10.7 and 10.8
What is the best HDV1080i 50 settings for finale cut pro 5? My easy setup wont let me log & capture.
It complete depends what you are recording in! PAL or NTSC? and how many frames... FCP is customized to your camera settings, match them up and then capture away!
I capture mine using a PC because then you can play around with both MAC and PC editing platforms as MAC captures are encrypted to only run on MAC.
- Scott
Hi, i have a problem with a sony z1 . it keeps saying eject cassette tape
u have ur cassette compartment problem.so try to press hard if it still trying come out.then checked the lock notch is there any bane .
How much use on a Sony HVR-A1U camcorder is too much?
dnt go for it ... u can have better option in z5, or z7 ..or z1 ...most of the camcorder a1 series have problem related to audio ....i will suggest dnt go for it ... its worth taking new dsr pd 170 for the same price
2answers
Head cleaning
Use good quality video head cleaning cassette as camera gives error if use improper or very old tape.
Help
dear ismaeel
maybe your problems is the type of file can't recognise by player that you used try use a codec software for that
try this site for a new codec
http://www.techsmith.com/download/codecs.asp
oke i hope this can solve your problems
cropp
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
