20 Most Recent Sony Alpha DSLR-A580 Body Only Digital Camera Questions & Answers
Tip
Join/Combine Canon HF M300 AVCHD MTS raw footage-Stream Canon MTS to Panasonic TV for watching
Best Mac Manage MTS Converter-Cut and Join Canon HF M300 AVCHD MTS clips to Panasonic HDTV with Highest Qulity <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to <b>Split and Merge AVCHD MTS files</b>. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces <b>how to split unwanted HF M300 record AVCHD .mts clips and join meaningful mts clips without conversion for playing on Panasonic HDTV</b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: <b>Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac.</b> <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b>Connect Canon Camcorder Movies to my Panasonic HDTV</b> via direct USB. Then <b><a href="http://sony-mts-converter.com/2011/06/joincombine-canon-hf-m300-avchd-mts-raw-footage-stream-canon-mts-to-panasonic-tv-for-watching/">Stream Canon HF M300 MTS to TV for watching</a></b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
on Aug 27, 2019 | Sony Alpha DSLR-A580 Body Only...
Tip
Best Mac Manage MTS Converter-Watch Merged Canon HF M300 AVCHD MTS Files on Panasonic TV
Split and Join Canon HF M300 Full HD MTS to Panasonic HDTV with no loss of quality <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to split and merge mts files. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces how to <b><a href="http://canon-videoconverter.com/2011/06/split-and-join-canon-hf-m300-full-hd-mts-to-panasonic-hdtv-with-no-loss-of-quality/">Split and Join HF M300 record AVCHD .mts clips for Watching/Playing on Panasonic HDTV</a></b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac. <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b><a href="http://www.aunsoft.com/final-mate-mac/">Connect Canon Camcorder Movies to my Panasonic HDTV</a></b> via direct USB. Then <b>Stream Canon HF M300 MTS to TV for watching</b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
Tip
DLNA Conversion-Seamlessly Connect and Watch Droid X Videos to HDTV through DLNA
If you have a look at Motorola Droid X, you may notice the Droid X is compatible with DLNA service. DLNA, as the short term for Digital Living Network Alliance, is to make it possible to view media between PCs, mobile devices and other consumer electronics. If you have a home wired or wireless network, e.g. Wi Fi network and a DLNA-capable TV, you can stream music, movies and photos from Droid X to TV. DLNA make it an alternative method to watch Droid X videos on TV besides HDMI output with Verizon Gallery app. <br /><br />Since we may sometimes do not have DLNA PC or transfer videos from PC to Droid X, we may face the problem of putting movies to Droid X. Here the guide will include two parts: one for <b><a href="http://www.aunsoft.com/video-converter/">DLNA Convert Movies to Droid X</a></b> and the other for <b>Streaming Movies from Droid X to HDTV</b>. <br /> <br /><b>Part I. Convert/Transfer movies to Droid X</b> <br />We need a powerful video to Droid X converter on Windows computer to make most videos compatible to Droid X. Aunsoft Video Converter is the right choice for converting TiVo, MKV, MTS, TOD, AVI to Droid X MP4. <br /><br />Step 1. Run Aunsoft Video Converter as the perfect <b>Droid X video converter</b>, and click the "Add" button to load HD videos in formats like .tivo, .ts, .mkv, .mts, .avi, .rmvb. <br /><br />Step 2. Choose Motorola Android MP4 format by clicking the "Format" option and navigating to <b>Android &gt; Motorola Droid (X) H.264 Video(*.mp4)</b>. <br /> <br />Step 3. <b>Convert HD videos to H.264 MP4 for Droid X</b> by clicking the start button under the preview window. After conversion, connect Droid X to PC via USB cable, and transfer videos to Droid X under the DCIM &gt; Camera folder. <br /><br />Part II. <b><a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Seamlessly Stream Droid X Videos/Movies to HDTV via DLNA</a></b>. <br />The DLNA service could be used as a stand alone, or used in combination with HDMI. A home network (wired or wireless) or WiFi network shall be set up with your DLNA compatible TV and Droid X. <br /><br />Step 1. Turn on Droid X and the TV, and select DLNA application on Droid X to start sharing media files. If you get the message to turn on Wi Fi connection, just click Yes and go to the settings menu to turn on Wi-Fi. <br /><br />Step 2. From the DLNA screen, select "Share media", and select the media (Video, Music, Picture) you want to play in the "My shared media" screen. Then click OK. <br /> <br />Step 3. Wait for a few seconds for <b>Connecting Motorola Droid X to TV based on DLNA</b>, and a green DLNA logo will appear at the top of Droid X screen for <b>Sharing movies and other media files to TV</b>. <br /><br />With the steps above, you can easily <b><a href="http://canon-videoconverter.com/2011/06/dlna-conversion-seamlessly-streamwatch-droid-x-videos-to-hdtv-through-dlna/">Connect and Watch Droid X video on TV through DLNA</a></b>. Hope it helps you play around your Motorola Droid X Android phone. <br /><br /><b>You may have interest in:</b> <br /><a href="http://www.aunsoft.com/put_and_play_movie_music_on_motorola_droid_x/">Put/play videos on Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_avi_to_motorola_droid_x/">Convert AVI files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_mkv_files_to_motorola_droid_x/">Convert MKV files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/top_droid_x_video_converter_convert_vob_to_motorola_droid_x/">Convert VOB Files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/convert_and_mount_videos_to_motorola_droid_x/">Mount Videos to Motorola Droid X</a>, <a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Stream Droid X Videos to HDTV via DLNA</a>, <a href="http://www.aunsoft.com/convert_videos_to_droid_x_verizon_gallery_for_playback_on_tv_via_hdmi/">Play Droid X Gallery Video on TV via HDMI</a>. <br /><br />Do you want to know more info about 2011 new smartphones and tablets? please enter <b>Aunsoft<a href="http://www.aunsoft.com/smartphones_and_tablet/">Smartphone and Tablet Column</a></b>.
Tip
Mac iPad 2 Blu-ray DVD Ripping Software-Rip Blu-ray to iPad 2 iOS 5
Downscale BD/DVD video to 1280x720 for iPad 2 with H.264 MP4 <br />Transfer Blu-ray DVD Movies to iPad 2-Rip/Stream Blu-ray DVD Movies to iPad 2 compatible MP4 format<br /> <br />The Apple iPad 2 has been unveiled, which is dual core, front and rear facing cameras, an all new A5 dual core CPU and a nine times more powerful GPU. With up to 10 hours battery life, 720p HD video support, 9.7 inch large screen. With such a cool tablet, you will not miss enjoying high quality Blu-ray/DVD movie for travel. But you can not play Blu-ray/DVD on iPad 2 directly. So how to let your iPad 2 become your Blu-Ray/DVD player with ease? The only way is to rip your favorite Blu-Ray/DVD movie from Blu-ray/DVD disc and then <b><a href="http://www.aunsoft.com/imedia-converter-mac/">Convert Blu-ray/DVD movie to iPad 2 compatible MP4 format</a></b>. <br /><br />Aunsoft iMedia Converter for Mac as a <b>Ultimate Blu-ray/DVD to iPad 2 Ripper</b> is powerful tool to remove the AACS(up to MKBv24), BD+, region code from any BD/DVD disc and rip Blu-ray/DVD to iPad 2 720p H.264 file for enjoying. Now just follow this guide. <br /><br />It is obviously that Blu-ray/DVD movies can not play on your iPad 2, so you need first rip your Blu-ray/DVD movie from Blu-ray/DVD disc and then convert it to iPad 2 compatible format, after that, using iTunes to transfer or sync. <br /><br />Step 1: Please download for free at: <b><a href="http://membercenter.aunsoft.com/download/?s=dc7edd5bce66308e4a77b3a84b500faa&n=www.aunsoft.com/imedia-converter-mac/">iMedia Converter for Mac</a></b>, install and launch. <br /><br />Step 2: Add Blu-ray/DVD movies into this <b><a href="http://www.aunsoft.com/imedia-converter-mac/">Mac iPad 2 Blu-ray/DVD Ripping Software</a></b>. <br />Click "BD/DVD Rom", "BD/DVD Folder" icon to load Blu-ray/DVD movies. You also can click the "IFO/ISO" button to load the .iso ,.ifo image file from your Mac computer for conversion. <br /><br />Step 3: Select subtitle for hard-burn into iPad 2 movie and audio track. <br />Click on the dropdown list of "Subtitle" and "Audio" respectively to select your needed subtitle and audio track. <br /><br />Step 4: Select iPad HD Video MP4 as output format. <br />Click the downlist menu of "Format" to select <b>iPad &gt; iPad HD Video MP4 for iPad 2</b>. For comparing H.264 MP4 and MPEG-4 MP4, you will get higher quality by choosing H.264 MP4, which is currently the best used format for the recording with its high quality and maximum compression. And choose HD H.264 MP4 can let you enjoy HD movie effect.The <b>Mac iPad 2 iMedia converter</b> will <b>Downscale BD/DVD video to 1280x720 for iPad 2 with H.264 MP4</b>. <br /> <br />Step 5. <b><a href="http://panasonic-avchd-converter.com/2011/06/downscale-bddvd-video-to-1280x720-for-ipad-2-with-h-264-mp4/">Convert BD/DVD files to iPad 2 iOS on Mac</a></b>. <br />Click the convert button under the preview window, and the <b>Mac BD/DVD to iOS 5 iPad 2 converter</b> will start converting Blu-ray/DVD Movies to iPad 2 format in 720p. <br /><br />When the conversion is done, use iTunes to <b>sync and transfer the 720p videos to iPad 2</b>. Then you can <b>Watch/Play Blu-ray/DVD Movies on iPad 2</b>. <br /><br />Tips: With this iMedia Converter for Mac software ,you also can convert and put/play TiVo, MKV, VRO, EVO ,AVI ,VOB .ect videos on iPad 2.It is a perfect combination of a Mac Blu-ray Ripper, Mac DVD Ripper and a Mac Video Converter.
Tip
Import and Convert Sony DSC-HX5V AVCHD MTS to Apple ProRes Codec MOV for Final Cut Pro on Mac
After recording your holiday videos using for example Sony DSC-HX5V, it would be nice to make a great home movie for sharing with family & friends. Sony HX5V is able to record 60 fields-per-second videos at 1080i (1,920 x 1,080 pixel) resolution with Dolby Digital stereo audio, using AVCHD compression. <br /><br />Regarding editing camcorder footage AVCHD files from Sony HX5V, the latest FCP 7 and iMovie 11 claims to give full support for the format but many people have experiencing difficulties either with importing process or output files. <b><a href="http://www.aunsoft.com/final-mate-mac/">Aunsoft Final Mate for Mac</a></b> is released for Mac users to better handle camcorder footage in a much easier and quicker way: <br />- Capture AVCHD MTS/M2TS files from camcorder <br />- Merge/Split in Timeline and <b>Convert to Apple ProRes codec for FCP</b> <br /><br />Aunsoft Final Mate for Mac is highly recommended to Mac users who are experience enormous inconvenience with AVCHD, TOD & MOD files from HD camcorder. It helps you directly capture video footages from Sony DSC-HX5V and then <b>Convert to Prores 422 MOV or AIC MOV without rendering on FCP/iMovie</b> on Mac. <br /><br />Here is the step-by-step guide for you to <b><a href="http://www.aunsoft.com/mac_convert_sony_dsc-hx5v_avchd_mts_to_apple_prores_for_fcp/">Import and Convert Sony DSC-HX5V MTS to Apple ProRes for Final Cut Pro</a></b> on Mac OS X. <br /><br />1. Capture/Import Sony HX5V AVCHD files to Aunsoft Final Mate for Mac. <br />There are two ways to import videos to Aunsoft Final Mate for Mac: you can directly capture video recordings from camcorder to the program or you can browser videos from your computer. <br /><br />- Capture Sony HX5V AVCHD videos from camcorder. <br />Connect camcorder to computer via USB cable, and then launch Aunsoft Final Mate for Mac in Application folder. With built-in wizard, you can easily to capture mts video files from HX5V to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under Camcorder tab in the main interface of Final Mate. <br /> <br />- Import Sony HX5V mts videos from computer. <br />If you have already backup all your video recordings from HX5V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in Resource tab. <br /><br />2. <b>Merge Sony DSC-HX5V AVCHD files into one movie for conversion</b>. <br />Click the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. <br /> <br />Once you've imported your video footage, drag and drop the video clips from Camcorder Tab (imported from your camcorder) or Resource Tab (imported from your computer) to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /> <br />3. <b><a href="http://www.aunsoft.com/final-mate-mac/">Convert Sony HX5V MTS files to ProRes Codec MOV</a></b>. <br /><br />Click the Export button and choose "Export into Editor". Follow Final Cut Pro&gt; Apple ProRes 422 HQ (*.mov) to choose export format for further editing in Final Cut Pro. Or you can also choose QuickTime Movie Format &gt; Apple Intermediate Codec (*.mov) for editing in FCE/iMovie. Click OK to start converting HX5V MTS files to ProRes MOV. <br /> <br />When the conversion process is done, you can directly <b><a href="http://sony-mts-converter.com/2011/06/import-and-convert-sony-dsc-hx5v-avchd-mts-to-apple-prores-codec-mov-for-final-cut-pro-on-mac-os-x/">Import the output ProRes MOV files to FCP for editing</a></b> and make your great home movies. <br /><br />You may also want to know how to <a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">convert AVCHD to Apple Intermediate Codec</a> for iMovie/FCE or <a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a> to preserve original quality.
on Jul 14, 2019 | Sony Alpha DSLR-A580 Body Only...
Tip
Merge/Combine Sony CX700V 1080/60p AVCHD MTS Movies without Re-encoding/Transcoding on Mac
Merge/Combine Sony CX700V 1080/60p AVCHD MTS Movies without Re-encoding/Transcoding on Mac Computer <br /><br />As one of the hottest products from Sony Hanycam line in 2011, <b>Sony HDR-CX700V</b> offers Full HD 60p and 28Mbps recording, as well as a traditional 60i record mode. With the camcorder's 96GB of internal flash memory, you are able to record long-time high definition videos. If you have recorded videos with your new <b><a href="http://www.aunsoft.com/review_sony_hdr_cx700v_high_definition_handycam_camcorde/">Sony HDR- X700V</a></b> for the special events like wedding receptions of your friends or relatives, birthday party of your little daughter or your holiday videos, you may want to make great home movies for enjoying high definition memories in big TV with your family & friends. So the question is how to retain its original 1080/60p 28Mbps video quality at best? <br /><br />Bundled software from Sony Picture Motion Browser may be able to help merge your video footage into one but it's only limited to windows version. If you use a Mac, <b>Aunsoft Final Mate for Mac</b> is highly recommended for dealing with camcorder footage. Actually, it's one of rare products on market that is capable of <b><a href="http://www.aunsoft.com/mac_merg-join_sony_cx700v_avchd_mts_without_re-encoding/">Merging AVCHD videos without any Conversion or Re-encoding</a></b>, which can preserve your original quality and enable you to enjoy your high definition memories on big TV. <br /><br />This guide introduces how to <b>Merge/Combine 1080/60p 28Mbps mts video files from Sony CX700V to one single file without transcoding on Mac computer</b> with featured product Aunsoft Final Mate for Mac nearly released by Aunsoft Studio. <br /><br />1. Capture/Import Sony CX700V AVCHD files to the program. <br />There are two ways to import CX700V mts videos to Aunsoft Final Mate for Mac: you can directly capture/copy/extract MTS clips from camcorder to the program o you can browser videos from your computer. <br /><br />- Capture Sony CX700V AVCHD videos from camcorder. <br />Connect CX700V camcorder to computer via USB cable, and launch Aunsoft Final Mate for Mac from Application folder. With built-in wizard, you can easily to capture mts video files from CX700V to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under "Camcorder Tab" in the main interface of Final Mate. <br /> <br />- Import AVCHD videos from computer. <br />If you have already backup all your video recordings from Sony CX700V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />2. <b><a href="http://www.aunsoft.com/final-mate-mac/">Join CX700V MTS files into one movie for lossless output</a></b> <br /><br />Click the drop-down button of "Add Movie" icon and choose "For Lossless Output" to create a blank movie. <br /> <br />Then drag and drop video clips from Camcorder Tab (imported from Sony CX700V) or Resource Tab (imported from computer) to this new movie. In this way, all your clips have been merged together as a whole complete movie for lossless output which means no re-encoding is involved. <br /> <br />3. <b><a href="http://sony-mts-converter.com/2011/06/mergecombine-sony-cx700v-108060p-avchd-mts-movies-without-re-encodingtranscoding-on-mac-computer/">Lossless output combined AVCHD movie without re-encoding</a></b> <br />Click Export button to start output your movie. You can find combined Sony CX700V MTS videos in output folder of your Mac machine without any quality loss. Plus as no decoding or re-encoding is involved, so the whole process of lossless output will be finished in only a few seconds or minutes. <br /><br />The guide can be also applied to other AVCHD, TOD, MOD camcorders from Sony, Panasonic, JVC, Canon camcorder brands. Aunsoft Final Mate for Mac could be an ideal companion for you to enjoy real HD experience on TV. <br /><br />Tip: you may also interested to know how to <b><a href="http://www.aunsoft.com/mac_convert_sony_dsc-hx5v_avchd_mts_to_apple_prores_for_fcp/">convert Sony AVCHD files to Apple ProRes</a></b> for editing in Final Cut Pro or <b><a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">convert AVCHD to Apple Intermediate Codec(AIC)</a></b> for editing in FCE/iMovie.
Tip
AVCHD merging software-Join AVCHD MTS Videos for Playing on Plasma TV without re-encoding
Lossless Join/Merge Sony AVCHD MTS Videos to Play on 1080p Plasma TV <br /><br />If you have bought a Full 1080p Plasma TV, no matter Panasonic, Samsung , Vizio, Pioneer, or Sony, and got a Sony AVCHD camcorder like Sony HDR-TG5V, Sony HDR-TD10, Sony DSC-HX5V, Sony Alpha NEX-5, Sony NEX-VG10, Sony HDR-XR520V, Sony HDR-XR500V, etc with 1080p or 1080i AVCHD recording in 2011, you may like to connect your Sony Camcorder to Plasma TV for sharing precious videos at home, but before enjoying, you may like to join the related videos and create home movie for series. <br /><br />The windows version of PMB (Picture Motion Browser) for Sony camcorders doesn't work well, and there is rare satisfied <b><a href="http://sony-mts-converter.com/2011/06/lossless-joinmerge-sony-avchd-mts-videos-to-play-on-1080p-plasma-tv/">AVCHD merging software</a></b> on the market, after searched, I found a professional AVCHD Joiner, which can be used as <b><a href="http://www.aunsoft.com/final-mate/">Sony MTS Joiner for Plasma TV</a></b>. With only three steps, the videos could be combined into one single file, keeping the original 16:9 aspect ratio, video format, video codec, bitrate, etc for HD playback on Plasma TV. <br /><br />Now I will show you the quick guide to <b>join Sony AVCHD videos to play on 1080p HD Plasma TV</b>. <br /><br />Step 1. Load Sony videos to Aunsoft Final Mate. <br />Connect Sony camcorder to PC with USB 2.0 cable, or use a card reader. Run Aunsoft Final Mate on Windows XP/Vista or Windows 7. Follow camcorder wizard included in Final Mate to easily capture and download AVCHD files from camcorder to the program. Or you can click on Browser button to locate your AVCHD file path and Final Mate will automatically show all Sony AVCHD MTS/M2TS files in Resource Tab. <br /> <br />Step 2. <b><a href="http://www.aunsoft.com/final-mate/">Join AVCHD files into one movie for Plasma TV</a></b>. <br />Click the Add movie button, and a movie for lossless output will be created by default. Select the files you would like to join into one file from the Camcorder tab (imported from your camcorder) or Resource Tab (imported from your computer), drag and drop to the movie. <br /><br />Step 3. <b><a href="http://www.aunsoft.com/final-mate/">Lossless merging MTS for Plasma TV without re-encoding</a></b>. <br />Click the Export button. As there is no video for conversion, just click the OK button for lossless output. The lossless output will be finished in a few seconds or minutes. When the merging process is done, just put the videos to the Plasma HDTV SD memory card slot and enjoy the movie.
Tip
Import MTS to Final Cut Pro X-Convert Sony PJ30V 60p MTS to H.264 MOV for Editing in FCP X
The Sony PJ30V has more compression options than your average camcorder. Most of its video is recorded using AVCHD compression, which is today's industry standard. The HDR-PJ30V has 32GB of internal flash memory and it can record Full HD video using 60p, 60i, or 24p frame rates. The PJ30V comes with the same version of Picture Motion Browser (PMB) software that shipped with the Sony HDR-CX700V, which we reviewed earlier this year. The new version of the software is nearly identical to previous versions of PMB, except version 5.5 does allow you to import and work with 60p and 24p clips (something that is essential for the HDR-PJ30V). One big downside, we noticed in terms of editing, is that the 60p clips recorded by the PJ30V don't always play nice with mac editing software. Final Cut Pro version 5.0, for example. And Now <b>Final Cut Pro X</b> is available could be Downloaded from the Mac App Store. However <b>Log and Transfer was removed</b> in the X version of Final Cut. So all Pro mts camcorder owners who use Final Cut are looking for <b>HD Camcorder MTS Converter Software</b>. <br /><br />Here is the step-by-step guide to quickly use Final Mate for Mac to <b><a href="http://sony-mts-converter.com/2011/06/import-mts-to-final-cut-pro-x-convert-sony-pj30v-60p-mts-to-h-264-mov-for-editing-in-fcp-x/">Import/Convert Sony PJ30V 1080/60p MTS to H.264 MOV for editing in FCP X</a></b> on Mac. <br /><br />Step 1. <b>Capture native MTS from Sony PJ30V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Import AVCHD MTS to Final Cut Pro X</a></b> on Mac, and drag the .mts files already backup all mts recordings from Sony PJ30V to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. <b>Create a Movie for combine and convert Sony PJ30V AVCHD MTS 1080p footage</b>. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /> <br />Step3. <b>Convert MTS files to H.264 MOV for Final Cut Pro X</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mov) to choose output format for editing in Final Cut Pro X. You can then adjust video parameters to keep original video resolution, bitrate, framerate, etc with highest quality. The <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac MTS to Final Cut Pro X Conversion</a></b> will start <b><a href="http://www.aunsoft.com/final-mate-mac/">converting MTS to H.264 MOV</a></b>. <br /> <br />After the conversion, the AVCHD videos could be imported to Final Cut Pro X with 60fps highest quality. Of course, you also can choose <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format for without rendering. ProRes is advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camcorder, please visit the <b><a href="http://www.aunsoft.com/camera/sony.html">Camcorder column</a></b> for more information.
Tip
Convert Sony HDR-XR550V AVCHD to Apple ProRes for FCP with AVCHD to Prores Converter
Sony Handycam HDR-XR550V records your memories and snap 12.1-megapixel photos directly to the massive 240GB hard disk drive (HDD). The shooting quality of the HDR-XR550V is impressive and naturally lives up to its flagship status and price. In line with Blu-ray formats in the market, recording is supported up to 24Mbps. High definition videos are recorded at 1920 x 1080 resolutions primarily to the in-built HDD. Picture quality was sharp and crisp, a result which was equally pleasing when viewing on a HD monitor or TV. <br /><br />Many people say Sony HDR-XR550V is the best hard drive camcorder from Sony at the moment and its excellent performance has won hearts of many customers. A lot of our customers use Sony HDR-XR550V for recording family videos, such as holiday vacation at east coast beach, your children?s birthday party or your pet?s playing video. In most cases, they want to do some basic editing and make great home movies to preserve their memories with highest quality. <br /><br />For windows users, it might be not such a problem as bundled software from Sony Picture Motion Browser is capable of basic editing and output videos to BD/DVD or upload to YouTube. But <b>How do you edit AVCHD on Mac OS X</b>? <br /><br />Final Cut Pro 6.0.1 update adds AVCHD transfer capabilities but is everything ok now? <br /><br />Apple's own Final Cut Studio 2 suite had a minor update for Final Cut Pro to version 6.0.1 which added the capability to transfer the AVCHD footage. But is everything really so promising for Mac users? I guess not. We?ve been receiving complaints and problems from our customers about their frustrating experience with AVCHD on final cut pro 6 or 7. <br /><br />Is there a simple and useful tool for Mac users to handle AVCHD for smooth editing in FCP without rendering? <br /><br />Aunsoft Studio nearly released product on Mac OSX <b><a href="http://www.aunsoft.com/final-mate-mac/">Aunsoft Final Mate for Mac</a></b> is specifically designed for camcorder users to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">handle, convert, share, playback AVCHD, TOD & MOD</a></b> high definition videos. <br /><br />In the article, I will take Sony HDR-XR550V as an example to show how to convert AVCHD MTS/M2TS video footage to Apple ProRes for smooth editing in Final Cut Pro 6 & 7. <br /><br />1. Capture/Import Sony XR550V AVCHD files to Aunsoft Final Mate for Mac. <br />There are two ways to import videos to Aunsoft Final Mate for Mac: you can directly capture video recordings from camcorder to the program or you can browser videos from your computer. <br /><br />- Capture Sony XR550V AVCHD videos from camcorder. <br />Connect camcorder to computer via USB cable, and then launch Aunsoft Final Mate for Mac in Application folder. With built-in wizard, you can easily to capture mts video files from XR550V to the program. Select ?Import? instead of Backup to quickly capture videos from camcorder. You can find imported videos under Camcorder tab in the main interface of Final Mate. <br /> <br />- Import Sony XR550V mts videos from computer. <br />If you have already backup all your video recordings from XR550V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in Resource tab. <br /><br />2. Merge Sony DSC-XR550V AVCHD files into one movie for conversion. <br />Click the drop-down button of ?Add Movie? icon and choose ?For Conversion? to create a blank movie. <br /><br />Once you?ve imported your video footage, drag and drop the video clips from Camcorder Tab (imported from your camcorder) or Resource Tab (imported from your computer) to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /><br />3. <b><a href="http://www.aunsoft.com/sony_hdr-xr550v_review_-_convert_avchd_to_apple_prores_for_editing_in_fcp/">Convert Sony XR550V MTS files to ProRes MOV</a></b>. <br />Click the Export button and choose ?Export into Editor?. Follow Final Cut Pro&gt; Apple ProRes 422 HQ (*.mov) to choose export format for further editing in Final Cut Pro. Or you can also choose QuickTime Movie Format &gt; Apple Intermediate Codec (*.mov) for editing in FCE/iMovie. Click OK to start converting XR550V MTS files to ProRes MOV. <br /><br />When the conversion process is done, you can directly import the output ProRes MOV files to FCP for editing without rendering and make your great home movies. <br /><br />The steps above are also applied to other AVCHD camcorders developed by Sony, Panasonic, Canon or JVC brands. <br /><br />Featured product from Aunsoft Studio Aunsoft Final Mate for Mac is the ideal companion for camcorder users who also use Mac machine to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">convert AVCHD to Apple ProRes</a></b> Codec. <br /><br />Tip: You may also be interested in converting <b><a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">AVCHD to Apple Intermediate Codec</a></b> for editing in iMovie or Final Cut Express or <b><a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a></b> to preserve original quality.
Tip
Transfer/Convert Sony HDR-CX150 AVCHD MTS Movie to Apple ProRes for Final Cut Pro on Mac
Transfer/Convert Sony HDR-CX150 AVCHD MTS Movie to Apple ProRes for Final Cut Pro on Mac <br /><br />Sony Handycam HDR-CX150 is listed as one of the best home movie camcorders by Lori Grunin, senior editor from CNET.com. However, people are not giving a high credit for this camcorder. Just like Lori puts it in her review for Sony CX150: "Its small size and attractive price might draw you to the Sony Handycam HDR-CX150, but this bare-bones camcorder just barely delivers on the promise of HD quality." <br /><br />For many Mac users, editing AVCHD footage on Final Cut Pro is not very pleasant with many problems & frustration, though Final Cut Pro 6.0.1 claims to give native AVCHD support. In the guide, I will share with you how to batch convert AVCHD MTS/M2TS videos to Apple ProRes format for smooth editing in FCP without rendering. <br /><br />Featured <b><a href="http://www.aunsoft.com/final-mate-mac/">Camcorder Software for Mac OS X</a></b> - <b>Aunsoft Final Mate for Mac</b> <br />Aunsoft Final Mate for Mac, a useful camcorder software program for Mac OS X, make it easy to capture AVCHD videos from camcorder, edit in Timeline for joining/cutting/splitting MTS/M2TS files, AVCHD lossless output for HD memories on TV, export to Final Cut or iMovie with provided Apple ProRes codecs & Apple Intermediate Codec, or share the fun online. <br /><br /><b>Highlights of Aunsoft Final Mate for Mac</b> <br />- Full HD support for AVCHD, TOD, MOD camcorders <br />- Support merging/spitting AVCHD without conversion <br />- Convert camcorder footage to Apple ProRes, AIC, Avid DNxHD Codec <br /><br /><b>How to <a href="http://www.aunsoft.com/mac_convert_sony_hdr-cx150_avchd_mts_to_prores_for_editing_in_final_cut_pro/">Transfer/Convert Sony CX150 AVCHD to Apple ProRes</a> on Mac OS X</b> <br />Learn how to convert AVCHD MTS or M2TS files to Apple ProRes codec via Aunsoft Final Mate for Mac with Sony CX150 as an example in the guide. <br /><br />Step 1. Import AVCHD MTS from CX150 to program. <br />There are two ways to import AVCHD videos to Aunsoft Final Mate for Mac. <br /><br />- Capture AVCHD videos from CX150 camcorder <br /><br />If you choose to import videos directly from camcorder to the program, first of all, please turn on Sony CX150 and connect it to your Mac via USB cable. Launch Aunsoft Final Mate for Mac and follow camcorder wizard to import videos to the program. Imported Sony mts files will be shown on Camcorder Tab of the program. <br /> <br />- Import AVCHD videos from computer <br /><br />If you have already transferred video footage from camcorder to your computer, you can browse the file path through "Add" icon. Then all AVCHD videos in the folder will show in Resource Tab of Aunsoft Final Mate for Mac. <br /> <br />Step 2. <b>Join MTS clips into one for conversion</b>. <br />In order to join AVCHD mts clips of Sony CX150 into a complete movie, all you have to do is to <b>drag & drop AVCHD videos</b> from Camcorder Tab or Resource Tab to Movies Tab. During the process, a pop-out window will show as below: <br /> <br />Choose "Create A Single Movie" to merge Sony CX160 MTS clips into one movie. <br /><br />Step 3. <b>Convert AVCHD Movie to Apple ProRes</b>. <br />Click on Export and then choose "Export into Editor". In the panel, please follow Final Cut Pro &gt; Apple ProRes 422 to confirm your output format to <b><a href="http://sony-mts-converter.com/2011/06/transferconvert-sony-hdr-cx150-avchd-mts-movie-to-apple-prores-for-final-cut-pro/">Convert Sony CX160V AVCHD Movie to FCP ProRes format</a></b>. <br /> <br />Step 4. <b>Transfer output ProRes MOV to Final Cut Pro</b>. <br />Import exported ProRes MOV movie from Aunsoft Final Mate for Mac to Final Cut Pro and start your smooth editing without rendering. <br /><br />If you love video making on Mac OSX, Aunsoft Final Mate is highly recommended as a practical <b><a href="http://www.aunsoft.com/final-mate-mac/">Camcorder Software on Mac</a></b>. <br /><br />Tip: You may also want to know how to <b><a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">convert AVCHD to Apple Intermediate Codec</a></b> for iMovie/FCE or <b><a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a></b> to preserve original quality. <br /><br /><b>Tags:</b> <a href="http://www.aunsoft.com/tag/best-camcorder-software-for-mac-os-x/">best camcorder software for Mac OS X</a>, <a href="http://www.aunsoft.com/tag/convert-mts/m2ts-to-apple-prores/">Convert MTS/M2TS to Apple ProRes</a>, <a href="http://www.aunsoft.com/tag/avchd-joiner/converter-on-mac/">AVCHD Joiner/Converter on Mac</a>, <a href="http://www.aunsoft.com/tag/convert-avchd-to-apple-prores-422-hq/">Convert AVCHD to Apple ProRes 422 HQ</a>
Tip
AVCHD to ProRes transcoder-Convert AVCHD footage to Apple ProRes for HD editing on FCP
Solution to Import AVCHD to FCP 7 from External Hard Drive <br />Get AVCHD files 1080i and 1080p editable on FCP-Transcode MTS/M2TS to ProRes <br /> <br /><br />I have many HD videos on my external hard drive for playback on the networked media player, Popcorn Hour. The files are in .mts format from different camcorders, Canon HF R20, Lumix TZ7 and Panasonic HDC-HS700. I would like to import them to Final Cut Pro 7 to make a DVD as present. <br /><br />Even though it is said that FCP supports the AVCHD files from the AVCHD folder structure, I could not get it work via Log & Transfer. When looking for the solution to import <b><a href="http://www.aunsoft.com/final-mate-mac/">AVCHD to FCP from External Hard Drive</a></b>, I notice that the problem might be related to the 1080/60p files from HS700. But I could not easy identify which file for 1080i or which for 1080p now. The only solution for me now is to <b>convert AVCHD to Apple ProRes 422 HQ for editing in FCP 7</b>. Aunsoft Final Mate for Mac is the recommended <b>AVCHD to FCP helper on Mac</b>, and it works perfectly with my HD videos. <br /><br />Hope the below simple steps would help you <b><a href="http://sony-mts-converter.com/2011/06/get-avchd-files-1080i-and-1080p-editable-on-fcp-transcode-mtsm2ts-to-prores/">Get AVCHD files 1080i and 1080p editable on FCP</a></b>. <br /><br />Step 1. Download AVCHD files to Aunsoft Final Mate for Mac. <br />Run Aunsoft Final Mate for Mac as the <b><a href="http://www.aunsoft.com/final-mate-mac/">AVCHD to ProRes transcoder</a></b>, go to the Resource tab, and click the Add file path button to browse the external hard drive. <br /><br />Step 2. Select files for conversion. <br />Select the files from the Resource tab, drag and drop to the Movie tab, to create new movie. Each movie ID would be saved as a file for output. If you want to join and merge the files, choose "Create A Single Movie". If you would like to leave the joining process to FCP, just choose "Create A Movie for Each File". <br /> <br />Step 3. Choose Apple ProRes 422 HQ for FCP 7. <br />Click the Export button, and go to the 3rd tab, then you can choose Final Cut Pro &gt; Apple ProRes 422 (HQ) as the output format for FCP 7. Set the output video size as 1920x1080. <br /> <br />Click the OK button, and the <b>AVCHD MTS/M2TS to ProRes transcoder</b> will <b><a href="http://www.aunsoft.com/final-mate-mac/">convert AVCHD footage to Apple ProRes for HD editing</a></b>. <br /><br />Wait for the conversion, and then you can <b><a href="http://www.aunsoft.com/final-mate-mac/">Edit HD videos on FCP 7</a></b> by choosing File &gt; Import &gt; Files. <br /><br /><b>Tips:</b> <br />1. You can change the output folder for storing the ProRes 422 files. <br /><br />2. To get videos without interlacing artifacts, just tick the box for deinterlace before clicking the Export button.
Tip
Watch MKV HD Videos on iPad 2-Convert MKV to iPad 2 Compatible Files
Best MKV to iPad 2 720p Converter-Stream/Play 1080p MKV to 720p MP4 on iPad 2 <br />Put and Play MKV Videos on iPad 2-Sync and Transfer MKV 720p Videos to iPad 2 <br /><br />For a HD movie fans, MKV is one of the most popular formats.It is a container format and most stored on blu-ray discs. We recognize it because of its high-definition effect and multi subtitle and track. But it is not recognizable by Apple iPad. I have downloaded some 1080p/720p MKV movie from internet on Mac and I think it must be pretty cool to watch MKV videos on the go with my newly bought iPad 2. If I want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Put/Play/Watch MKV HD Videos on iPad 2</a></b> and iPad anywhere anytime, I need to <b>Stream/Sync/Convert MKV to iPad 2</b> supported video and audio files first. <br /><br /><b>Before converting MKV to iPad, we'd like to show you more information about MKV:</b> <br />MKV file is an open source container format. It is a general-purpose audio and video container and a competing format to the more popular AVI and MP4 formats. With its futuristic design approach, it can provide support for a vast number of audio, video and subtitle compression formats. Its features exceed even those of AVI and MP4 files. An MKV file contains compressed video and audio streams along with an encoder. A codec or Coder/Decoder is required to play this type of file. MKV aims to be the leading standard for multimedia container formats. It is based on EBML, a subclass of XML. <br /><br />So if I want to play MKV files on my new iPad 2, it's necessary to convert MKV to iPad 2 compatible files. I need is a <b>Mac MKV to iPad 2 Converter - Aunsoft <a href="http://canon-videoconverter.com/2011/06/best-mkv-to-ipad-2-720p-converter-streamplay-1080p-mkv-to-720p-mp4-on-ipad-2/">Mac iPad 2 Video Conversion</a> ( PowerPC Compatible)</b>, which can easily convert MKV for iPad 2 with 720p high quality. <br /><br />Have a look at the steps below to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert MKV videos to iPad 2 on Mac</a></b>, and output movies to HD 720p resolution. <br /><br />Step 1. Load MKV movie files you want to <b>Put/Transfer/Sync and Play on Apple iPad 2</b>. <br />Free Download Aunsoft Mac MKV to iPad 2 Converter and install. After launching the iPad 2 Video Converter for Mac, please load your MKV video file by drag and drop or click 'Add' button to load kinds of videos. <br /><br />Step 2. Choose iPad 2 720p MP4 format. <br />Click the "Format" option, and navigate to iPad &gt; iPad 2 HD Video(*.mp4) as output format. iPad 2 supports 720p video playback, video formats with H.264, MPEG-4. The Profile default size 768*576, you must choose 1280*720. Then output format is iPad 720p resolution. <br /><br />Step 3. <b>Convert MKV to MP4 on iPad 2</b>. <br />Click the convert button under the preview window, and the <b>Mac MKV to iPad 2 converter</b> will start <b><a href="http://www.aunsoft.com/video-converter-mac/">converting 1080p/720p MKV to 720p iPad 2 MP4</a></b>. <br /><br />When the conversion is done, use iTunes to <b>Sync and Transfer the 720p Videos to iPad 2</b>. Then you can <b><a href="http://sony-mts-converter.com/2011/06/best-mkv-to-ipad-2-720p-converter-streamplay-1080p-mkv-to-720p-mp4-on-ipad-2/">Put and Play MKV Videos on iPad 2</a></b>. <br /><br /><b>Tips</b>: At the WWDC 2011, Apple unveiled iOS 5 system, and some testers have got the iOS 5 beta on iPad 2 to play 1080p HD videos flawlessly. If you want to play 1080p videos on your iPad 2, you can choose HD Video - HD H.264(*.mp4) and set 1920*1080 mp4 as video codec ,save as iPad 2 1080p MP4.
on Apr 07, 2019 | Sony Alpha DSLR-A580 Body Only...
Tip
Xbox 360 DLNA-Convert and Play MKV to WMV files on Xbox 360 via DLNA
While Xbox 360 is a popular video game console for many game lovers, Microsoft also provides large space up to 250GB for making Xbox 360 more than a video game console. Most users many take Xbox 360 and a part of the home entertainment with the Xbox Live Marketplace and home movie collections. <br /><br />Xbox 360 Supports video files in Windows Media Video (WMV) format, ASP, H.264 and MPEG-4 media in .mp4 format. If you downloaded MKV videos from hd-torrents.org, you need to convert the <b>HD MKV videos to Xbox 360 WMV</b> before playing them. Aunsoft Video Converter is the best HD <b><a href="http://www.aunsoft.com/video-converter/">MKV to Xbox 360 Conversion</a></b> on Windows to make it easy to play WMV on Xbox 360 via DLNA. <br /> <br />Follow the step-by-step guide below to <b><a href="http://www.aunsoft.com/top-notch_hd-torrents_mkv_to_wmv_converter_for_xbox_360_with_dlna/">Convert and Share MKV to WMV files on Xbox 360 via DLNA</a></b>. <br /><br />Step 1. Load MKV to Aunsoft Video Converter. <br />After downloading MKV from torrent sites, just run Aunsoft Video Converter as the best MKV to Xbox 360 converter, and click the "Add" button to import batch of .mkv videos. <br /><br />Step 2. Choose Xbox 360 WMV format. <br />Click the "Format" option and choose <b>Zune/Xbox 360 Device &gt; Xbox 360 HD Video(*.wmv)</b> as output format. The Xbox 360 video converter will convert MKV to WMV for perfect playback on Xbox 360. <br /> <br />Step 3. <b>Convert MKV to WMV for Xbox 360</b>. <br />Click the convert button under the preview window, and the MKV to Xbox 360 converter will start converting MKV torrent videos to WMV for playing on Xbox 360. <br /><br />You can easily <b><a href="http://sony-mts-converter.com/2011/07/xbox-360-dlna-convert-and-play-mkv-to-wmv-files-on-xbox-360-via-dlna/">Play the WMV Files on Xbox 360 via DLNA</a></b> after copying the video files to Xbox 360 and <b>Watch Videos on DLNA-compatible HDTV via network</b>. <br /><br /><b>Tips:</b> <br />For playing Blu-ray disc movies on Xbox 360, you can use <b>Aunsoft <a href="http://www.aunsoft.com/blu-ray-video-converter-ultimate/">Blu-ray Video Converter Ultimate</a></b> to rip and convert BD movies to WMV for Xbox 360.
Tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for FCP editing
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
on Mar 17, 2019 | Sony Alpha DSLR-A580 Body Only...
Tip
Best Conversion to ProRes 422-Convert/Merge Flip Videos to ProRes MOV for FCP on Mac
The <b>Flip Video</b> is a camcorder for digital video created by Pure Digital Technologies. Variants include the Flip Ultra, the Flip UltraHD, the Flip MinoHD (1hr), the Flip MinoHD (2hrs) and the Flip SlideHD. The great Flip Video camcorders record videos in 640&times;480 resolution at 30 frames per second, using the MPEG-4 ASP video compression. The high definition versions record at 1280 x 720 resolution using H.264 video compression, AAC audio compression and the MP4 file format. <br /><br />However, Flip Video can not edit in iMovie, FCP, FCE etc. How to convert Flip Video to iMovie, FCP, FCE etc for editing Flip Video easily? <br />Now with <b>Aunsoft <a href="http://www.aunsoft.com/video-converter-mac/">Mac Flip Video Converter</a></b>, you can convert Flip Video, Flip HD Video files to Apple ProRes 422 MOV, ProRes 4444 MOV, Apple Intermediate Codec MOV etc with no loss of quality for above uses. At the same time, you can get perfect video/audio synchronization, fast conversion speed and editing your Flip Video by trimming, cropping, merging, adding watermark, effecting and more. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/best-conversion-to-prores-422-convertmerge-flip-videos-to-prores-mov-for-fcp-on-mac/">convert Flip Video to ProRes Codec on Mac</a> (*.mov)</b> for editing in Final Cut Pro. <br /><b>Step1:</b> Download, launch the Aunsoft Flip Video Converter and add your Flip Video files to the program. <br /><b>Step 2. Choose Final Cut Pro-Apple ProRes (*.mov) output format.</b> <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac Flip Video to FCP Converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Flip Video to Apple FCP ProRes MOV</a></b> with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 3. <b>Merge Flip footage Video files. (optional)</b> <br />Tick the checkbox for "Merge into one file", and the Flip Video to FCP Converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b>Convert Flip Footage Video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac Flip Video to FCP Converter will start the conversion from Flip MP4 Video to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily <b><a href="http://www.aunsoft.com/video-converter-mac/">Import Apple Prores MOV to Final Cut Pro without rendering</a> for editing</b>. <br /><br /><b>Tips:</b> <br />If you would like to edit Flip MP4 Video with FCE/iMovie, Avid, etc, you can convert Flip Video to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode flip videoS to Avid DNxHD (*.mov) for Avid on Mac.
Tip
Transcode/Convert AVCHD MTS/M2TS Video to FCP Apple ProRes 422 without rendering on Mac
<b>Apple ProRes 422</b> is a standard-definition and high-definition lossy video compression format developed by Apple Inc. for use in post production. It was introduced in 2007 with Final Cut Studio 2 and is comparable to Avid's DNxHD codec which has the same purpose and uses similar bit rates. Both are DCT basedintra-frame-only codecs, and are therefore simpler to decode than distribution oriented formats like H.264. FCP/FCP7 is Mac based editing software which supports transcoding AVCHD MTS/M2TS to Apple ProRes for further editing. <br /><br /><b>AVCHD MTS/M2TS</b> files produced by HD camcorder like Panasonic HDC-TM700, HDC-HS700, HDC-SD700/SD600, Sony CX350, Sony CX550, Canon HF200, etc are not the preferred formats by FCP/FCP7. Even you will have problem for transferring and logging these MTS, M2TS videos. <br /><br />So the program you need is a great <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac MTS Video to Apple ProRes 422 Converter</a></b>. With it, you can convert any HD camcorder 1080 60p/50p, 1080i AVCHD (*.mts, *.m2ts), 720p AVCHD lite files to Apple ProRes 422 for editing with Final Cut Pro, Final Cut Pro 7 on Mac. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/transcodeconvert-avchd-mtsm2ts-video-to-fcp-apple-prores-422-without-rendering-on-mac/">Transcode/Import AVCHD to FCP Apple ProRes 422 Codec (*.mov)</a></b> for editing. <br /><br />Step 1. Download MTS/M2TS files to Apple computer. <br />Connect your AVCHD camcorder c to Apple computer via USB cable, find the .mts, *.m2ts files from the camera folder like PRIVATE &gt; AVCHD &gt; BDMV &gt; STREAM. Then copy and transfer the .mts, *.m2ts files from camera to the Apple hard drive disk. <br /><br />Step 2. Import MTS/M2TS files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">best AVCHD to FCP Apple ProRes Converting software</a></b>, and click the "Add" button to load AVCHD .mts or .m2ts videos. You may also directly drag and drop the AVCHD video to application UI for importing files. <br /><br />Step 3. Choose Final Cut Pro-Apple ProRes (*.mov) output format. <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac MTS/M2TS Video to FCP Converter will convert AVCHD to Apple ProRes 422 MOV with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 4. <b>Convert AVCHD MTS/M2TS video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac MTS/M2TS to FCP Converter will start the conversion from AVCHD to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily import <b><a href="http://www.aunsoft.com/video-converter-mac/">Apple Prores 422 to Final Cut Pro without rendering</a></b> for editing. <br /><br /><b>Tips:</b> <br /><br />If you would like to edit AVCHD MTS/M2TS with FCE/iMovie, Avid, etc, you can convert MTS/M2TS to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode MTS/M2TS to Avid DNxHD (*.mov) for Avid on Mac.
Tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing FCP 6/7
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
Tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
Tip
Convert/Import Canon HF M300 MTS Videos to ProRes for Final Cut Pro X with High Quality on Mac
Canon FCP X-Transcode/Edit Canon HF M300 MTS to ProRes 422 for FCP X <br /><br />To save the storage space of my Canon HFM300 and shoot more ,I used to copy the videos I like from the camcorder to my Mac and delete the others. Recently I want to edit the videos I shot in my graduation year with FCP X and then share the MP4 videos on youtube. The problem is that I do not have the whole BDMV folder and therefore, cannot import MTS Videos to FCP X on Mac. I tried many products and thanks to <b>Aunsoft Final Mate for Mac</b> - <b><a href="http://www.aunsoft.com/final-mate-mac/">2011 Best Import and Edit Software</a></b>, it helps me solve the problem. Following I am very glad to share my experience of importing MTS files with Aunsoft Final Mate for Mac and <b><a href="http://prores-converter.com/2011/07/editimport-canon-hf-m300-mts-videos-to-prores-for-final-cut-pro-x-on-mac-with-high-quality/">Import and Convert MTS files to Apple ProRes for editing on FCP X</a></b>. <br /><br />1. Import MTS videos from Aunsoft Final Mate for Mac. <br />One great feature of Final Mate for Mac is that it can import MTS files without the whole BDMV folder. Click the "Add A Path" icon to browse the Mac and select a folder where MTS video files are saved, then click "OK" to display the videos. The MTS files are imported to the Final Mate for Mac. <br /> <br />2. Create a movie for conversion. <br />Click the drop-down button of "Add A Movie" icon and choose "For Conversion" to create a blank movie. Then drag and drop the MTS files from Camcorder Tab to the blank movie. <br /><br />3. <b>Export Apple ProRes or Apple ProRes 422 for Editing on FCP X</b>. <br />Click the little icon on the right side of the movie and choose its output format as "Apple ProRes 422" under "final cut pro", click the "Export" button and Start <b>Convert Canon MTS to ProRes/ProRes 422</b> <br /> <br />4. <b>Edit Apple ProRes on FCP X</b>. <br />After conversion is completed, you can <b><a href="http://www.aunsoft.com/final-mate-mac/">Edit Apple ProRes on FCP X</a></b> and then share it to youtube. <br /><br /><b>Tips:</b> <br />Aunsoft Final Mate for Mac can only import videos of AVCHD, TOD, MOD temporarily, for videos of other formats like mxf, mov and mp4,you can use <b><a href="http://www.aunsoft.com/video-converter-mac/">Video Converter for Mac</a></b>to help you.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
409 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
mac driver download panasonic dmcsz02k
  • Cameras
