HI,
Could be you just need to update your drivers, before you take it apart try this:
Follow the steps mentioned below to check what Updates are installed on the system.
See which Windows updates are installed
http://windows.microsoft.com/en-US/windows7/See-which-Windows-updates-are-installed
Error Code 0F00:133C
Msg: DISK- No suitable disk media is present.
This error message is encountered when you probably have a bad video card and/or flaky RAM.
Step 1:
Unplug all the External devices such as printers, scanners etc and check whether you encounter this error message.
Step 2:
I would suggest you to install the latest drivers for the Video card from the dell website and check
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
For further reference check the article mentioned below.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 3:
Iwould suggest you to configure Chkdsk to run when the system restarts next time. Follow the steps mentioned below to configure Chkdsk to run when the Windows Vista restarts next time.
a.Click Start and then Run.
b.In Open, type cmd and then press ENTER.
c.Use one of the following procedures:
Procedure 1: To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
Procedure 2:To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note: If one or more of the files on the hard disk are open, you will receive the following message:
a.Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
b.Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Procedure 2: To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
I got this information @
0F00 133C Error Code No suitable disk or media is present written by Thahaseena M, Microsoft Answers Support Engineer.
