20 Most Recent Dell Studio 15 Laptop Questions & Answers
You need Dell support.
Dell Studio 15... | Answered on Dec 16, 2018
any available touch pad on the market is windows compatible. just try out which works for your needs.
Dell Studio 15... | Answered on Feb 20, 2018
Hi
Try the following:
1. Fn + F2
2. Update or install latest version of wireless drivers.
3. The problem could be with the F2 and F4 Keys on the keyboard, in this case the keyboard needs to be replaced.
You can reach out vendor for a replacement if it is under warranty.
Dell Studio 15... | Answered on Oct 12, 2017
It may be an issue with your harddrive
Dell Studio 15... | Answered on Sep 21, 2017
yes, how ever you must format them install windows 2003 server first on its own partion on the hard drive, and then install windows xp in its own hard drive.
how ever,, each OS has its own operating system, and depending on what your planning to actually do with them may determine how well thier gonan work. Example if your just gonna use them for class room exercises so your students can learn and manage a lan website on their computers then it might be ok. if you wanna host actually websites, then your gonna run into a lot of issues especially with space.
your avg dell studio specs
Processor
  • Processor Intel Pentium Dual Core T4300 / 2.1 GHz
  • Multi-Core processor technology Dual-Core
  • 64-bit processor Yes
  • Data bus speed 800.0 MHz
  • Chipset type Mobile Intel PM965 Express
Memory
  • Type L2 cache
  • Cache size 3.0 MB
RAM
  • Installed Size 3.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 400.0 MHz
these are all well above what you would need to run the OS.
please mark this as fixya if it was helpful
Dell Studio 15... | Answered on Dec 02, 2016
I had the same issue with my Dell XPS 15z, after looking every where to get instruction to get the CD out. I decided to call Dell Tech Support and it did work.
1. Turn off the laptop
2. Turn on the laptop and press F2 several times until the setup menu come up
3. Then press the eject botton from the keybord, the Cd should come up.
Good luck
Dell Studio 15... | Answered on Apr 15, 2015
It could be a virus, run anti virus to clean this up
Dell Studio 15... | Answered on Jan 05, 2015
on the keyboard where all the numbers are written (on the right hand side) try the very top left key
on the dvd drive, there should be a small hole, use a pin and push into that hole, it will manually eject the drive
Right click on the speaker icon from system tray (on the right hand bottom corner)
Select Troubleshoot sound problems
Check if the button for opening the disc drive isn't damaged and stuck in. Try cleaning that, restart laptop and try again
Could be a software problem.
Can you start in safe mode ?
Dell Studio 15... | Answered on Dec 14, 2014
It might be cloged and unballanced with dust Try using a compressed air cleaning bottled . to remove the dust, if it is still making noise I would suggest that you have it repaires because if it stop completely it could overheat your motherbord and cause dammage
Have you tried removing and replacing the battery, while the computer is open ?.
Sometime this method reset the charging process
It sounds like the DVD drive button is damaged or faulty - I would just continue to use the eject from the Windows,explorer window or have the drive replaced.
Dell Studio 15... | Answered on Nov 29, 2014
If you cannot eject a DVD or CD from the drive, you will find a small hole in the drive cover - Take a paper clip and straighten it, then poke the clip through the hole, then gently but firmly push, and the tray will open.
There are 2 settings at least for volume. One is within you tube and the other is the computer system volume. The system volume generally can be found at the bottom right of the task bar. It will look like a speaker. Right click or left click that for different options
Dell Studio 15... | Answered on Oct 23, 2014
Find your way into control panel and check mouse settings I believe the middle mouse button is adjusted there. The details are different with each brand of mouse but this should point you in the right direction.
Favourites are stored in
C:\Users\name_of_user\Favorites.
Put in your own name!
You can copy the files there to the library of your choice.
Dell Studio 15... | Answered on Oct 13, 2014
Dell Studio 15 Laptop Logo
322 questions posted
Ekse
Clive
Clive
View Most Popular
Studio Dell
  • Studio Dell
Most Popular Question
bios boot 1555
  • Computers & Internet
